C++ in Cfx
Old   December 22, 2008, 12:37
Default C++ in Cfx
fabian
Dear Friends
can i use C++ in CFX?
I would appreciate if some one give a hint
thank you
diego
Old   December 23, 2008, 06:32
Default Re: C++ in Cfx
Johnson
It depends what you want to do.
If you want to call C/C++ routines that exist in a library from a User CEL Function or Junction Box Routine during the solver run, you should be able to do this quite easily.
If you type 'cfx5mkext -help' at the command line I think there is an example of doing this at the bottom of the help entry.
Regards,
Johnson
Old   January 18, 2009, 23:04
HekLeR
Yes, this can be done.
The CFX solver is expecting to call a fortran function, but as long as you correctly account for name mangling, hidden string length arguments & pass by reference, it should work fine.
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
