Exit code 247
Old   February 4, 2009, 06:41
Default Exit code 247
Adam
Hi Does anyone know what an exit code of 247 means?
Is it memory related??
here's the verbose information:- MPI Application rank 0 killed before MPI_Finalize() with signal 9 An error has occurred in cfx5solve:
The ANSYS CFX solver exited with return code 247. No results file has been created.
thanks for help
Old   February 5, 2009, 08:26
Default Re: Exit code 247
Joey2007
MPI is hint to parallelization. Nevertheless to sure the failure is not caused by your setup take an tutorial example and start in the same as you do yet.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
Debugging Unsteady 2-D Panel Method Code: Wake Modeling RajeshAero Main CFD Forum 5 November 10, 2011 05:48
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 04:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
