heat flux is found to be zero!
Old   February 16, 2009, 12:29
Default heat flux is found to be zero!
vijay
Dear friends, I was solving an external flow problem using CFX. The body was subjected to hypersonic flow (M=6). Results were converged. I assumed body surface as adiabatic wall. I could see the temperature distribution over the surface of the body but heat flux was found to be zero over the surface. I could not make out the mistake. Kindly suggest me. As it was the first trial, I used coarse mesh. But i am feeling that it should have shown atleast some variation in the heat flux. It was completely zero. Thank you.
Old   February 16, 2009, 13:15
Default Re: heat flux is found to be zero!
cfdguy
I hope I haven't misunderstood your post but if the heat flux is zero in your surface, most likely it's because you've set as Adiabatic.
Regards.
Old   February 16, 2009, 13:16
John S.
Are you running a heat transfer problem? Unless the model was set up to run heat transfer it can't calculate a heat flux through a surface.
Old   February 17, 2009, 03:41
Default Re: heat flux is found to be zero! *NM*
Timon
Old   February 17, 2009, 03:42
Timon
adiabatic = no heat flux over system boundaries
Old   March 3, 2009, 17:28
Jules
Yes, I am running into the same problem. My FLUENT mesh is symmetric on the north, south walls which is the same meshed wall. The north wall is fine, but the south has heat flux at zero. The walls are not adiabatic. So, I am still looking for the problem.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
