May 29, 2009, 03:57 |
How to detect errors in the mesh
Rosa Esposito
Rep Power: 16 |
Hallo to everyone.
I am solving one case with the electromagnetic features, and the simulation clerly diverges due to one error in the mesh that I don't manage to find. I am aware that with electromagnatic feature parameteres like the Volume Change are quite important, and I tried to have one uniform mesh. Unfortunately, I have to reduce the numebr of nodes somewhere, in order to not have some kind of 10000000 nodes simulation. My question is: if I manage to change something in the output parameter in PRE, can I detect the point of the mesh who gives me problems, and so to try to change the mesh with one purposefully strategy? I can upload the file somewhere, every help is welcome. |
May 29, 2009, 07:05 |
Rep Power: 17 |
Output the equation residuals and look up where the maximum residual occurs. This will give you an idea of the source of your (mesh-related) convergence issues.
May 29, 2009, 07:24 |
Rosa Esposito
Rep Power: 16 |
Thanks a lot. I did it.
The mesh is something like 5000000 nodes and I need some time for the results. My problem is: the simulation is good, till something goes wrong and the in some part of the mesh the Temperature jumps to high (not acceptable) values, and then diverges. So, if I understood good, is it enough to look whare the residual have some high values, and there I find the problem? Last edited by rosaesposito; May 29, 2009 at 07:35. Reason: Grammar error ;-) |
May 29, 2009, 07:56 |
Rep Power: 17 |
Basically yes. It at least gives you an idea at which location the solver breaks down. If you find bad element-quality in this area then convergence might be helped by improving the mesh locally. Otherwise, try reducing your timestep...
Hex-Tet Mesh Merge in ICEM | Tristan | CFX | 1 | September 26, 2008 05:40 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 12:16 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
