pond depth
Old   July 1, 2009, 10:44
Default pond depth
Johannes Gérson Janzen
jgersonj is on a distinguished road
Dear friends,
I have no experience with CFX. I need to simulate the hydrodynamics of stabilization ponds. I am encountering difficulties in defining the water depth in the pond. At the beginning of the simulation the pond must already have some depth of water. How do I do that?
Thanks
jgersonj is offline   Reply With Quote
Old   July 1, 2009, 11:42
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
Originally Posted by rui View Post
second, have a look at the "free-surface flow over a bump" tutorial, and see how they define the water heigth.
Rui
Rui is offline   Reply With Quote
Old   July 2, 2009, 03:31
Ali Torbaty
AliTr is on a distinguished road
you should make some expressions to define volume of water and volume of air through initialisation.
1- define an expression for initial water level, say: InitWatLevel = 2[m]
2- make a step function defining water volume: WatVol = step((InitWatLevel - z)/1[m])
3- make a step function defining air volume: AirVol = 1 - WatVol
4- use WatVol and AirVol expressions in Domain/Initialisation to define volume fraction of each fluid
good luck
ps. check Tutorial 7: Free Surface Flow Over a Bump
AliTr is offline   Reply With Quote
Old   July 2, 2009, 03:48
Rui
Rui's Avatar
Rui Igreja
5- don't forget the hydrostatic pressure \rho\cdot g\cdot h
Rui
Old   July 3, 2009, 12:21
John is on a distinguished road
The height of the pond should be controlled by outlet weir. Try to find the outlet weir elevation and do a simple math.
John is offline   Reply With Quote
Old   July 6, 2009, 16:13
Default + pond depth
Thanks for the reply.
The pond consists of one inlet pipe and one outlet pipe. The output may be in a position below the inlet. As inlet condition, I'm defining the normal speed. In the pond the conditions are similar as in the manual:
h = 2 [m]
initialVOFAir step = ((z - h) / 1 [m])
initialVOFWater = 1 - initialVOFAir
initialP = 998 [kg m ^ -3] * g * (h-z) * initialVOFWater
As outlet condition, we adopted the normal speed (which equals the speed of entry). What is the error that is being committed?
Old   July 6, 2009, 16:38
ckleanth's Avatar
George
ckleanth is on a distinguished road
Originally Posted by jgersonj View Post
... What is the error that is being committed?
you tell us ...
btw the equation initialVOFAir = step((z - h) / 1 [m])
you forgot to define the air pressure in the pressure initialisation
PS if you have multiphase leave one phase volume fraction initialisation as automatic.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   July 7, 2009, 11:02
h = 2 [m]
The level of the lagoon can be controlled by the operators by adjusting the outlet exit level depending on the seasonal condition. So depending on what you really want to model, it usually should good enough to determine the water level based on traditional hydraulic calculations or based on outlet pipe elevation. And since the lagoon has very large area, it is also acceptable to simplify the inlet/outlet structure for the modeling purpose.
For designing optimization purpose, you may also consider a worst case scenario water level and use it as your modeling base
Depth for 2D problems Jamcam FLUENT 9 February 21, 2018 13:24
pond depth jgersonj Main CFD Forum 1 July 1, 2009 10:38
How did I set a discharge or depth curve at inflow boundary? (open channel problem) Andy Chen FLUENT 0 June 29, 2009 10:11
More replies below current depth... !!!! Rui Site Help, Feedback & Discussions 6 May 15, 2009 09:46
Pond Boundary Conditions J.W. FLUENT 0 August 24, 2004 18:03
