Simulation of Flow through Complex 3D Geometry |
July 2, 2009, 06:15 |
Emerson Kirk-Burnnand
As part of my final year engineering project, I am comparing the performance of a number of supercharger intake plates. Specifically I am looking at the intake plates of twin helical screw type compressors, similar to that shown below. Initially I developed a 3D model of the intake plate using Solidworks. Now the geometry actually a number of webs which branch from the bearing housings out to the plate itself. These webs include quite complex geometry due to the profiling on the underside. This results in a face which not only joins the bearing housing tangentially, but also tapers down to zero width at the same time. This is best described with a picture, The plane was to (as a simplified flow model), model flow through a simple geometry matching the outline of the intake plate, with the plate removed from this geometry using a boolean cut opeartion. Again, this is made clear with a screenshot where the green geometry will be the flow region and the grey body is the plate which will be cut from this geometry. Resulting in the following geometry, This 3D model was exported for use in CFX via the Parasolid file format. Initially I had a lot of trouble getting CFX-Mesh to work with this geometry as whenever I selected 'Verify Geometry' or 'Generate Surface/Volume Mesh', the program would display 'Waiting for meshers to start...' for a long period of time and would not progress. After extensive trial and error I decided the cause of this was poorly structured topology in the parasolid file. Using the program CADFix, I was able to restructure the parasolid files to a point where CFX would happily generate a mesh for the geometry. After dealing with a few expected problem sliver faces and short edges, I was able to generate meshes with good resolution along the intake plate surface as well as inflation layers surrounding the plate and flow region walls to help resolve boundary layer flows. However, the resulting volume mesh contains 800,000 elements. This seems very high and will result in long solution times. In addition to this I am not yet sure if my mesh is fine enough and may infact need (many) more elements. I am after some guidance as to whether I am approaching this problem the right way. Is there a more suitable method of modelling the flow then the boolean cut geometry I am currently using? Is there a better way to deal with CFX freezing on 'Waiting for meshers to start' then using CADFix? Is there a more suitable meshing method/application I should use? I find there is a very limited amount of tutorials regarding the ANSYS Workbench/CFX workflow process and the tutorials that do exist deal almost entirely with 'perfect'/'ideal' geometry. Also there seems to be very little published literature where flow through complex 3D geometry has been simulated. |
July 2, 2009, 06:37 |
George
Rep Power: 18 |
difficult project for final year engineering course. I'm surprised if this is not an msc course final year project at least.. anyway
to simplify get yerself access to v12 use the immersed solids beta function (although this will affect only the hydrodynamic equations) so turbulence modeling effects is no go at the moment. meshing is much easier as you only need to mesh the fluid domain and the solids... separately get your project supervisor to agree with this and you will finish this on time. otherwise....
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
July 2, 2009, 06:38 |
George
Rep Power: 18 |
however you could do this as a 2D analysis- ask your supervisor
July 2, 2009, 06:46 |
Rep Power: 143 |
First off - unless you have CFX V12 then you have no hope of doing this. The immersed body feature in V12 will make this relatively easy to do, but in any previous version of CFX this will be almost impossible. So make sure you have V12. From your images it does not look like you are making full use of the CAD importing tools in ANSYS workbench. You should simplify the surfaces much more than you currently have to improve the mesh quality. (Virtual surfaces and the like) It will also improve meshing speed. Do the tutorials in V12 dealing with importing dirty CAD geometry. You seem to have excessively fine mesh in some areas and excessively coarse mesh in others. You will need to improve this for analysis. I would not go down the 2D path. A 2D model will not tell you anything of use in this analysis. Regards, Glenn |
July 2, 2009, 07:00 |
I believe I can get access to ANSYS V12 at my university. I'll look into the immersed body feature some more.
Do you know of any published (or not) literature that deals with similar flow simulations over three-dimensional geometries such as this? I know companies do these types of simulations all the time, ex: flight and aerospace companies, however it seems there is very little publicly available research. Most papers consider only 2D geometries or simplify complex 3D geometry to 2D. Thanks for your help, I'll see how I go with ANSYS v12... |
July 2, 2009, 08:17 |
George
Rep Power: 18 |
just an alternative thought..
since you are in academia contact http://convergecfd.com/ and ask whether they would be interested to support you with their software regarding your project and all. they cant compete with the ansys multiphycis software capability but for the physics setup you would be using I think this is another good chance for you to complete this project.
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Transient Simulation for pipe flow | Sam | CFX | 0 | January 7, 2005 00:06 |
Better for Simulation of Dense Solid-Lquid Flow ? | Jeniffer | CFX | 0 | November 22, 2003 19:42 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
