Help Needed: Polyline intersection in Post
Like Tree1Likes
  • 1 Post By longbow
Old   July 3, 2009, 04:18
Default Help Needed: Polyline intersection in Post
PHabib is on a distinguished road
Hallo all,
I'm currently trying to make a polyline as intersection between two planes in ANSYS Post. The only method that I found is to intersect a plane with a boundary. Does anyone know how to build the polyline (or similiar) as intersection between two user-planes? e.g. to make a polyline at a given distance in front of a blade at 50% span (intersection with a vertical plane at given distance and a hoizontal plane at 50% blade span).
PS: I'm using ANSYS 11.0
Help will be much appreciated, thanks in advance
Habib
PHabib is offline   Reply With Quote
Old   July 7, 2009, 03:43
smn
smn is on a distinguished road
hi:
this is also my problem in post-processing!!!
thx for your help
smn is offline   Reply With Quote
Old   July 8, 2009, 04:15
Hi smn,
glad to know I'm not the only one with the problem.
(btw are you thanking me? I think I didn't gave a solution whatsoever )
Old   July 10, 2009, 08:09
longbow is on a distinguished road
Unfortunately, CFX-Post does not allow user to create polyline from the interaction between two planes. The workaround is to put a contour on horizontal plane at 50% blade span. That contour should use axial coordinate as variable with only two levels. Make contour range min or max at where you want to create polyline. Now you can create polyline from contour.
Mazze[ITA] likes this.
longbow is offline   Reply With Quote
Old   July 13, 2009, 04:04
Thumbs up
Hi longbow, thank you very much for the solution. I'll try to use the workaround.
Polyline at intersection of two planes Francesco CFX 2 July 29, 2009 08:03
Post processing free surface. Juan Martin Catelén CFX 2 April 20, 2007 13:20
different value in post - help needed tuks CFX 8 April 29, 2005 16:47
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
Urgent help needed in post!!. processing results.. Deadly FLUENT 0 August 21, 2002 00:42
