July 12, 2009, 10:18 |
Unsteady problem
Girish Oppattaiyyanamath
Dear all,
I am working on Unsteady heat conduction problem with two solid domains and in CFX I could able to generate DISTANCE vs TEMPERATURE plot at particular time interval. But I am neither able to generate TIME vs TEMPERATURE plot nor can export the values of TEMPERATURE at a particular time. Hope you help me to sort out this problem... |
July 12, 2009, 19:40 |
Rep Power: 143 |
Two approaches can be done: 1) Set up a number of Monitor points along the section you want the plot and get them to output temperature. Run the simulation and you will be able to generate the profile versus time. 2) Setup transient output files to output the temperature field. Then use CFD-Post to extract the temperature data along your section. You can do the charting in CFD-Post if you like or export it and do it in another package. Glenn Horrocks |
July 13, 2009, 22:47 |
#3 | |
Yi-Lang Chen
Rep Power: 17 |
Can you tall me how did you use unsteady mosel. Because I didn't find unsteady button, I only find steady and transient. Please tell me, thanks! |
July 14, 2009, 00:59 |
Rep Power: 143 |
Unsteady is the same as transient. Same thing.
July 15, 2009, 08:32 |
Jack
Rep Power: 16 |
Dear Sir Andy,
see this tutorial about the transient simulation. Rogerio. http://www.4shared.com/file/72198900...tionpart1.html http://www.4shared.com/file/72199871...tionpart2.html |
July 15, 2009, 08:57 |
#6 | |
Yi-Lang Chen
Rep Power: 17 |
July 15, 2009, 12:44 |
Jack
Rep Power: 16 |
July 15, 2009, 12:46 |
#8 | |
Jack
Rep Power: 16 |
Hi Mr. girishom,
how did you build the interface regions among the domains (fluid and solids)? Quote:
unsteady state velocity problem | Vedavyasa M | FLUENT | 0 | June 28, 2007 06:33 |
Problem in Reporting Unsteady Particle Fates | Nelson | FLUENT | 0 | August 23, 2006 20:24 |
Under relaxation factor for unsteady NS scheme? | zonexo | Main CFD Forum | 0 | September 26, 2005 21:15 |
unsteady state problem | prasad | FLUENT | 0 | April 4, 2002 22:44 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
