Can CFX user function be used to extract wall pressure and face element area? |
July 19, 2009, 08:35 |
Rep Power: 16 |
Hi all:
I am now doing some work about FSI. I want to extract the wall element area and its cooresponding static pressure. Can user fuction be used to do this work ? Thank you for your attention!! |
July 20, 2009, 02:16 |
Rep Power: 143 |
Forget fortran. You can easily do this in CEL. Read the CFX documentation on CEL Expression language.
Glenn Horrocks |
July 20, 2009, 03:42 |
what about the area and pressure of vertices "
Rep Power: 16 |
Hi , thank you very much for replying this topic. I want to extract the coordinate, area and pressure of all the vertices of a wall boundary. Is the CEL capable to do this work ?
Thank you ! |
July 20, 2009, 18:44 |
Rep Power: 143 |
Why do you want the coordinates, area and pressure of all vertices? Glenn Horrocks |
July 20, 2009, 22:32 |
The coordinates and force act as loads
Rep Power: 16 |
In case that all the coordinates, areas and pressure of a wall boundary are exported, they can be used to calculate loads. Then the loads will be assert on a structure to calculate its deformation. Thank you for your attention |
July 20, 2009, 22:36 |
Rep Power: 143 |
Sounds like a standard FSI model. No need to do anything like fortran to export nodes. Just look in the tutorials for example FSI simulations. Glenn |
user fuction |
How to read pressure at discrete points | paka | OpenFOAM | 16 | April 28, 2020 07:26 |
boundary pressure value at the face open to atmosp | Gaurav Mehra | FLUENT | 0 | April 21, 2008 09:50 |
UDF to monitor minimum pressure on the wall | Arvind Jayaprakash | FLUENT | 0 | September 20, 2007 11:53 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
