Total Mesh Displacement X not available in v12.0?? |
July 31, 2009, 08:18 |
Tim B
Rep Power: 17 |
Hi
I had specified mesh displacement like x0 = x - Total Mesh Displacement X in an expression in v11.0 Now trying to do the same in v12.0, it gives me an error saying the variable is unavailable. Looking at the documentation, the variable is "Total Mesh Displacement" but without the X or Y. Is this right and how would I calculate my x0 from now on? Many thanks |
August 2, 2009, 00:16 |
Rep Power: 143 |
You have not specified how you want to deal with the variable. Maybe areaAve(Total Mesh Displacement X)@region? Glenn Horrocks |
August 3, 2009, 08:09 |
Tim B
Rep Power: 17 |
I wasn't using any of those functions (like areaAve) in v11.0.
Basically, I'm setting a moving mesh. So, I defined the expressions (simplified): X0 = x - Total Mesh Displacement X //original node locations X New = X0*cos(angle) - Y0*sin(angle) //new location x Motion = X New - X0 //relative movement And then set in the boundary conditions "specified displacement" X = x Motion. This runs fine in v11.0. But in v12.0 it doesn't. Don't understand why I should use weighted area average, I was under the impression, X0 is calculated for each node separately. What am I missing here? |
August 3, 2009, 19:11 |
Rep Power: 143 |
OK, I see now. I was not aware of any changes to the handling of anything here in V12. There are a number of ways of specifying the mesh motion (specified displacement, specified location etc) so you might have to try a few of them to find one which works. It might also be worthwhile talking to support to find out what has changed here. Glenn Horrocks |
August 4, 2009, 03:44 |
Tim B
Rep Power: 17 |
Thanks, Glenn. Support has ignored all my requests so far. Probably because I am on an academic license.
I'm going back to 11.0 which is quite frustrating as I set up a whole bunch of models in 12.0 WB and none of them can be used in v11.0. Just opening DM with a 12.0 model throws up lots of exceptions... |
August 4, 2009, 06:15 |
George
Rep Power: 18 |
could raise a support request in your behalf if you want - pm me if you want me to go forward (will need a simple case in v11 and v12 to email to ansys)
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
October 1, 2009, 09:39 |
Svein K
I have the excact same problem. A bit different expressions, but same error message and the v11. to v12. problematique.
Found any solutions? Svein |
December 10, 2009, 08:47 |
zeitistgeld
Rep Power: 17 |
I do have the same problem. How so? Does anybody know about it? Is it a bug?
December 10, 2009, 15:18 |
#9 |
Tristan Burton
Rep Power: 17 |
I switched over to the 'Specified Location' option for describing the mesh motion since I couldn't make 'Specified Displacement' work properly with CEL and the Total Mesh Displacement variable in CFX 12.
July 9, 2010, 09:12 |
#10 |
Minnick
Has anyone resolved this issue? I have the same problem. Specifying moving object displacement OR position as a function of time is often very difficult if you can't reference where the object was before the displacement started.
CFX is definitely aware of what the original position of a displaced point was because it uses it when it calculates new position by setting "Specified Displacement". So, there must be a variable for this. Anyone know what it is? |
March 9, 2011, 05:58 |
#11 |
James
Rep Power: 15 |
Hi
I have recently had the same problem using v12.0... I spoke to ansys support and they said that 'total mesh displacement' wasnt available in this version- but this was rectified in v12.1 and v13. regards James |
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
Structured mesh refinement | Andrea Panizza | FLUENT | 1 | November 9, 2003 03:48 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
