4 core & 8 core: same 64bit XP, Xeon, x5570, 2.93GHZ |
August 12, 2009, 15:09 |
lee ruoyun
for same *.def file, run both on 4 core & 8 core workstation (other config are same: 64bit XP, Xeon, x5570, 2.93GHZ)
see cpu info here: http://picasaweb.google.com/leeruoyu...56084054998514 4 core is converged within 300 iterations, while 8 core not converged within 300 why ? CPU bothers ? thanks for advice ! version: CFX12 64 bit |
August 12, 2009, 23:06 |
Rep Power: 143 |
It is unusual for adding extra processes to affect the convergence of the simulation. What type of simulation is it?
Glenn Horrocks |
August 14, 2009, 02:58 |
lee ruoyun
thank you !
it is really strange. any random initilization for CFX ? e.g., how solver to kick off the flow with the prescribed turbulent intensity ? In this case, we would always get different results for different run (i do not believe this as when i run 2 time in the same pc, results are same), puzzled ........ slower or faster we should always get the same thing ah ... |
August 16, 2009, 08:24 |
Rep Power: 143 |
CFX only uses random numbers (to my knowledge) in modelling lagrangian particles with turbulence and in generating inlet/initial conditions for LES models. I do not know of any other random numbers used in CFX - but I am not a developer so I am only guessing. You still have not described what you are doing. Glenn |
August 19, 2009, 00:47 |
lee ruoyun
hi i am doing porous media (seepage flow) problem... i will test another case soon (free surface problem) ...
Dual Xeon PIV 3.8Ghz vs 2x Dual Core E5130 2.0 GHz | Michiel | Hardware | 4 | July 31, 2009 06:06 |
Questions about CPU's: quad core, dual core, etc. | Tim | FLUENT | 0 | February 26, 2007 14:02 |
Core 2 Duo vc. Dual Core Xeon 3060 | Jan | Main CFD Forum | 6 | February 20, 2007 06:21 |
