August 13, 2009, 05:17 |
How to use sas turbulent
dss
Rep Power: 16 |
Hi:
I want to use sas turbulent model to calculate tubulent. But I don't konw what I will pay attention to . Wish every one gives me some suggestion. Thinks! |
August 13, 2009, 06:22 |
Rep Power: 143 |
Only consider using these advanced turbulence models such as SAS once you know exactly what you are doing and you have shown the simpler turbulence models are not adequate. Glenn |
August 13, 2009, 22:41 |
SAS setting
dss
Rep Power: 16 |
Hi: Glenn
Thinks for your suggestions. I know the SAS turbulent model's idea, but I use LES to simulate the turbulent, the results are good.however, I change turbulent model to SAS model, the results are not good. I use the same time step. I guess perhaps some paremeters which I set are not good. So, I want to ask for setting methods on SAS model. Thinks! |
February 16, 2010, 11:11 |
SAS source term Qsas
Gert Lindner
Rep Power: 16 |
F. Menter described in his paper [Revisting the turbulence scale equation] some test cases, e.g. for self-similar flows (Csas=0.54 for a round jet). I can find in the latest theory guide (12.1) that the default value in CFX is set to Cs=0.11. The question is, how can I change the value of Cs ?? The documentation (p.86) indicates compliance with zeta2=3.51 (== SAS2 Coeffiecient in CFX-Pre) , sigma_Phi=2/3 (diffusion constant), but what means SAS1- SAS3- Coeffiecient?
Regards Gert |
June 4, 2011, 02:04 |
mohammad
Rep Power: 16 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 10:24 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
low turbulent reynold number | C-CARE | CFX | 4 | March 12, 2004 06:36 |
About low Re number turbulent flows | gorka | Main CFD Forum | 13 | April 2, 2003 05:19 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
