Pressure velocity coupling
Old   August 22, 2009, 06:09
Arrow Pressure velocity coupling
Raiyaz Ahamed
L Raiyaz Ahamed is on a distinguished road
Which algorithm (SIMPLE, SIMPLER, SIMPLEC, ...) is used as default in CFX, If we want to change the algorithm what is he procedure.
L Raiyaz Ahamed is offline   Reply With Quote
Old   August 29, 2009, 11:08
kingjewel1 is on a distinguished road
CFX uses a Coupled solver which means velocity and pressure are solved simmultaneously. SIMPLE* are all segregated solvers which rely on a pressure correction term and hence the pressure drives the velocity. Check CFX theory guide pdf. if you don't have it, it's easily downloadable. You can't change the solver algorithm, that's FLUENT's domain.
kingjewel1 is offline   Reply With Quote
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 20:04
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
