run cfx post in batch
Like Tree3Likes
  • 3 Post By ghoshi1983
Old   August 28, 2009, 14:25
Default run cfx post in batch
al mazdeh
amazdeh is on a distinguished road
I have heard that CFD post-processor, has a feature called session file, which this capability in batch mode which can be applied to quickly reproduce output for a series of runs. Can u show me how to do that
I have to create a bunch of text file containing data of my transient run
It is so hard to do in GUI-It takes forever
amazdeh is offline   Reply With Quote
Old   September 10, 2009, 11:23
ghoshi1983 is on a distinguished road
1-load res file in CFX post then select New session (e.g test.cse).
2-Click Recording session.
3-After done with whatever you want to do with post processor.
4- click stop recording.
As soon as you are done with recording the session. You will get a .cse file
(test.cse).
then you can run it in batch mode:
cfx5post.exe -batch test.cse test.res
Where test.res, for example is your result file from simulation.
ctsalico, yuqian and carolalucena like this.
ghoshi1983 is offline   Reply With Quote
Old   September 25, 2020, 00:08
Default Reference Macros
balaji_hrrn's Avatar
Fluidic Heat
balaji_hrrn is on a distinguished road
While the easiest way is to get the commands from a recorded session, as stated earlier - if you desire more options, you can refer to the Macros directory in the installation folder. You can search for *.cse and look at typical macros for Turbines, Compressors and Pumps. You can look at how to declare variables, assign values, array operations - depending on your needs.
balaji_hrrn is offline   Reply With Quote
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
batch mode in CFX mehul CFX 5 October 26, 2005 07:19
data output from batch fluent run Wang FLUENT 4 March 11, 2005 11:01
CFX POST mpeg Revisited henry CFX 2 November 22, 2002 11:42
creating expresions in cfx build or cfx post alex CFX 1 August 22, 2002 13:01
