winglet analysis
Old   September 18, 2009, 14:00
Default winglet analysis
kumar
cfd_lean is on a distinguished road
I am Intended to do CFD analysis on wing with winglets using CFX. I have wind tunnel results. i need to match ,my CFD data to experimental results.
I generated a grid with Icem. I generated def file using CFX pre.
The inlet conditions , known are Dynamic Pressure and free steam mach number ans Reynolds number. I did know the outlet conditions.
Initially i started CFD runs using Velocity magnitude as inlet and atmospheric pressure as outlet. Solution did not converged and failed after 30 iterations. Then I tried by changing outlet condition to static pressure(roughly took 0.95% inlet Ps). Here also i did not get luck. I tried with keeping opening boundary condition at the outlet. Still I did not get any luck.
Let any one can suggest me how to proceed further & what modifications I need to do for setup?
cfd_lean is offline   Reply With Quote
Old   September 18, 2009, 23:22
Baldy is on a distinguished road
Inlet - Velocity
Outlet - 0 relative pressure
Baldy is offline   Reply With Quote
winglet analysis cfd_lean Main CFD Forum 1 September 18, 2009 14:51
What exactly is a sensitivity analysis? Josh CFX 3 August 19, 2009 09:18
Fan Boundary conditions with external analysis Rob FloEFD, FloWorks & FloTHERM 1 February 10, 2009 00:04
Questions on Analysis Controls and Runtime Control Arnab Siemens 1 October 26, 2004 09:47
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
