Ben
Rep Power: 16 ![]() |
I am currently performing a series of ventilation studies using cfx that require a meshed person (human body) within the space to be analyzed. Unfortunately when i try to integrate the body within the space in my cad program (rhino), the once perfect nurbs body now has a series of holes and cannot be properly meshed in ansys. Without trimming him however the are no meshing errors. So now instead of basically welding his feet to the floor (to make a single interior volume), I would like to have him float in space (just above) but still act as an object within the fluid. Can I have him act as a floating boundary/wall? How do I go about specifying his geometry in this way. I can't seem to figure this out although it is probably fairly basic. Atm he is just considred another fluid region. Thanks for any help you can give, Ben. |
Rep Power: 17 ![]() |
What format is he?
Ben
He was created in rhino by me using tsplines (A plugin).
So he can be any nurbs filetype really. The problem is within rhino. It creates errors when cutting him up. His geometry is perfect(spent hours to make sure it was) until trimmed. That is why I have resolve to have him float in space since I don't have to cut him up. By floating I mean just no contact on the surface of the main wall boundary. |
Rep Power: 143 ![]() ![]() ![]() ![]() |
It makes no difference to CFX whether the person is attached to the floor or an isolated body levitating in space. It all gets treated the same - a wall boundary condition.
Sounds like you have a solid modelling problem. You would have to talk to Rhino people to resolve that I guess. |
Ben
Well when I have him floating in space it considers him an isolated fluid region and not just a wall for some reason. I get a isolated fluid region error. If I by pass it in advanced settings, the fluid just flows right through him.
Thanks for the reply! I appreciate it... (Problem is driving me crazy) |
Sounds like you are splitting the block into two blocks rather than chopping a bit out of the big block. Still sounds like a solid modelling problem - although in CFX-Pre you can set the domain to only use one section of the mesh (in the mesh tree) and ignore the other section so if you know what you are doing you won't need to remesh.
I've only had a small amount of contact with rhino so let me get this straight. When you do a Boolean subtraction, ie cutting the man out of the block, it leaves you with holes?
I think you can import both meshes separately into CFX and merge them by interfaces without any extra work. I may be wrong about solid-fluid though. |
I have no experience with Rhino so cannot help you with using it. But make sure you know the difference between surface bodies and solid bodies - if you cut a surface body from a solid body it make well chop the solid body into two sections.
In CFX-Pre you can import these meshes and use them together or separately or merge them. |
Floating object with 6DoF in InterDyMFoam | wavytracy | OpenFOAM Programming & Development | 2 | November 5, 2010 10:28 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
