December 4, 2009, 01:49 |
CFX transient analysis
Rep Power: 16 |
Dear all,
I'm setting up a transient analysis which involves coil, insulation,lamination,housing and water model. The heat source are from the coil and lamination which are applied as Watts per unit volume. 3 domain interfaces were defined. interface 1: water channel between water and housing faces interface 2: lamination slot and insulation faces interface 3: coil and insulation faces After starting the run, i observed that in the Solver, there's a window for Heat Transfer-1, and Heat Transfer-2. In Heat transfer-1, i observed oscillations as shown in attached file. 1) Is this oscillation of concern please? i've set RMS residual target to be 1e-5. 2) i would like to input temperature-dependent material properties. How do i do this in CFX-Pre please? Thank you for your kind attention, and i look forward to hear of any comments/suggestions.
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
December 4, 2009, 05:00 |
Rep Power: 143 |
It is normal for the thermal time-scales to be far slower than the fluid timescales and this leads to convergence problems. You should consider whether this really needs to be done as a transient simulation or whether a steady state simulations (or a series of steady state simulations).
Sometimes you need double precision numbers in runs with great variations in timescales. But you also need to do all the normal checks of mesh, convergence and timestep size. |
December 6, 2009, 01:11 |
Rep Power: 16 |
Any idea how temperature-dependent material properties can be input into CFX please? in case a transient analysis needs to be done.
courant number for transient flow on CFX ? | amine | CFX | 13 | August 20, 2013 19:02 |
Restart of transient analysis | usker | STAR-CD | 0 | April 3, 2009 00:49 |
CFX 2D ANALYSIS BOUNDARY CONDITION | fat bug | CFX | 1 | February 19, 2008 16:22 |
Tracer Analysis in CFX | Graeme | CFX | 11 | October 25, 2005 10:02 |
transient analysis of silencer using cfx. | mehul | CFX | 0 | October 16, 2005 04:48 |
