Too large temperature decreasing above sound speed |
December 5, 2009, 16:44 |
Roland Rakos
Rep Power: 17 |
Hello CFX Users,
I am often engaged in compressible flow and I have a problem: If the Much number is larger than 1, so the temperature decreases overly. (For example: In a very thin gap -150K (!) has developed) I know that this temperature decreasing comes from the energy equation but in my opinion the wall friction should compensate this large temperature decreasing....at least partially. (So it seems to me that the CFD does not take into consideration the effect of the friction properly...) Did anybody experience this problem? Thanks; Roland |
December 6, 2009, 04:34 |
Rep Power: 143 |
I seem to remember answering this before....
Firstly - can you explain how you got a negative absolute temperature? This is an obvious boundedness problem so you have a major problem there. Secondly - Can you explain why you think wall friction has much of an effect on the temperature? Thirdly - If you want to include viscous heating just activate the option. It is built into CFX but I strongly doubt it is what you are looking for. |
December 7, 2009, 11:28 |
#3 | |
Roland Rakos
Rep Power: 17 |
Besides I tried an other approach too: I defined outside temperature and heat transfer coefficient at the wall, but the temperature was very low still (about -80 C). (The theme of my experimentation is a simple 2D laval nozzle.) |
December 7, 2009, 13:46 |
Roland Rakos
Rep Power: 17 |
Consequently I understand that the effect of the wall friction is not too large in terms of the temperature increasing, but I don't think that -80 C is able to develope in the reality...
December 7, 2009, 17:17 |
Rep Power: 143 |
Why not? Have you looked at the temperature an ideal gas will get to at the pressures you have through a gap of the size you have?
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Speed of sound (mesh movement) | AliAli | CFX | 5 | October 18, 2009 07:12 |
Abt: the speed of sound in incompressible flows | jinwon park | Main CFD Forum | 3 | August 21, 2008 20:44 |
negative speed of sound | Bearcat | Main CFD Forum | 5 | August 6, 2008 12:55 |
Decreasing temperature of combustion | Jacek | FLUENT | 5 | February 18, 2002 00:45 |
