Tank Discharging (Boundary Condition)
Old   December 17, 2009, 17:11
Default Tank Discharging (Boundary Condition)
Eli
Eli is on a distinguished road
Hi there!
I'm trying to simulate a simple "tank discharging" problem. There is a hole at the bottom of the tank as an outlet. I wonder what the best Boundary Condition is for outlet!
The hydrostatic pressure can be a good prediction, but it deponds on water height in the tank that is decreasing by time!
How can I set such a B.C that varies with time and need to be updated every timestep???
Thank you very much
Eli is offline   Reply With Quote
Old   December 17, 2009, 20:46
Tristan Burton
Tristan is on a distinguished road
If the tank is discharging then you should use the ambient pressure that it is discharging to as the outlet boundary condition. The hydrostatic pressure doesn't make sense since the fluid is discharging and therefore not static.
Tristan
Tristan is offline   Reply With Quote
Old   December 18, 2009, 06:11
Eli
Thank you Tristan for your answer!
Well, somthing that makes the fluid discharge is the weight of it above the outlet, isn't it? Does CFX understand it when we use ambient pressure?
Thanks again
Old   December 18, 2009, 14:15
Tristan Burton
I'd never noticed that there is no gravity checkbox available in CFX. Can you add a momentum source to introduce the force due to gravity?
Tristan
Old   December 19, 2009, 13:31
Question
Eli
of course CFX has gravity option! when you activate Buoyancy Force, it means that you are including gravity in your simulation.
but the point is:
"the pressure calculated by the solver when buoyancy is activated, excludes
the hydrostatic pressure gradient"
anyway, can anyone help me set a boundary condition using some variables from transient result?
Old   December 20, 2009, 20:32
Ali Torbaty
AliTr is on a distinguished road
I assume you have a tank full of water with an outlet at the bottom. and model is a multiphase Air/Water (buoyancy activated).
you need two boundaries.
First is an open boundary at the top (tank roof) set to Pres & Dirn, 0 Kpa. Air volume Fraction=1, Water Volume fraction=0. this will ensure air ingress when water leaves the tank.
Second boundary is similar to the fist one but at your outlet. This will ensure gravity discharge into atmospheric pressure.
Make sure that you have enough mesh refinement around the outlet, say at least 8 diagonal nodes.
AliTr is offline   Reply With Quote
Old   December 21, 2009, 15:02
Eli
Dear AliTr
Thanks for your respond
I'm going to check it ,and if it doesnt work out I'll come back sooon!
Eli
Old   December 22, 2009, 08:42
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
Have a look at these:
http://www2.dem.uc.pt/antonio.gameir...SEAS_paper.pdf
http://www.wseas.us/e-library/confer...rs/498-704.pdf
http://www.ansys.com/magazine/issues...r-products.pdf
http://www.ansys.com/industries/cons...oiletvalve.htm
... and though it may sounds simple, the discharge of tank is a difficult numerical problem (transient, two-phases, free-surface), and very CPU time consuming. But I'm sure you'll find it by yourself.
Rui
Rui is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
problem with boundary condition??? smn CFX 5 November 24, 2009 06:37
Help Urgent about changing boundary condition Anjum Naveed FLUENT 7 August 14, 2006 12:25
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
