January 14, 2010, 15:26 |
Eddy Viscosity Model Parameters
Tristan Burton
Rep Power: 17 |
Does anyone know where the turbulent Prandtl number, and turbulent Schmidt number for additional variables are set inside CFX-Pre? I'm using the k-epsilon model along with the total energy equation and a transport equation for an additional variable. I can find where all the model constants are defined for the k and epsilon equations, but not for the total energy equation (turbulent Prandtl number) and the additional variable transport equation (turbulent Schmidt number).
Thanks, Tristan |
January 14, 2010, 16:52 |
Rep Power: 143 |
If you can't find a keyword in CFX-Pre then look in the RULES file. It has the complete listing of the available CCL commands. It is in <CFX_ROOT>/etc/RULES
January 14, 2010, 17:46 |
Tristan Burton
Rep Power: 17 |
Glenn,
Does that mean that those parameters (turbulent Prandtl number and turbulent Schmidt number) are "hardwired" into the code? If I wanted to I could change the k-epsilon model coefficients in CFX-Pre, but I can't do the same for the total energy equation and additional variable equation? Thanks, Tristan |
January 15, 2010, 23:08 |
Rep Power: 143 |
CFX-Pre does not access the full CCL. Some commands need to be set using CCL. The RULES file is the complete syntax. Don't edit the RULES file or you will simply break CFX.
January 20, 2010, 13:59 |
Tristan Burton
Rep Power: 17 |
Glenn,
Which tutorial provides details on how to set commands with CCL? Tristan |
January 20, 2010, 15:25 |
Rep Power: 16 |
Hi
I think that for any problem it is diffrent. For example in free surface problems you can see the tutorial 7. God luck Tajnesaie |
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES | Marvin | Main CFD Forum | 6 | December 4, 2009 11:08 |
eddy break model using usrsrc routine | dj | CFX | 0 | October 14, 2003 00:15 |
regarding eddy break up model | dj | CFX | 0 | September 30, 2003 02:05 |
effective viscosity in RNG k-e turbulence model | Ellen | Main CFD Forum | 1 | August 20, 2002 02:20 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
