January 16, 2010, 08:46 |
Joule heating convergence problem
Shahid Parvez
Rep Power: 16 |
Hi
I am simulating Joule heating. There are two domains, one is solid electrode (copper) and other is Fluid (Argon with temperature dependent electrical conductivity and others). I apply current at the top of the solid electrode as electric field flux in. Simulation converges at a current flux of 25 [A m-2] but when I change it to actual value of 25000000 [A m-2] the solution diverges after 4 iterations. Error message is bellow: +--------------------------------------------------------------------+ | ****** Notice ****** | While evaluating Static Enthalpy, | Static Pressure | went outside of its lower limit. Its minimum value was | -2.4670E+11. The bounds error was handled by clipping. | If this situation persists, consider increasing the table range. +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | Message: | Fatal overflow in linear solver. +--------------------------------------------------------------------+ Help please... Regards |
January 16, 2010, 16:03 |
Attesz
Rep Power: 17 |
Only guess, the problem is with the fineness of your mesh...
January 16, 2010, 16:09 |
Rep Power: 143 |
Looks like a simple divergence to me. Fixing it could mean many things. Also there is a power 1e6 difference between your two tests - that probably means they have very little in relation to each other, just as a Re=1 flow looks nothing like a Re=1e6 flow. Try some intermediate fluxes.
You will almost certainly need a smaller timestep for the higher heating rate one. Also local timescale factor to start things off might help. Also consider simplifying the problem. Start with the simplest physics possible and get that to converge. Add the physics one at a time until you have all the physics working. Also have a look here: http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
January 16, 2010, 23:02 |
Shahid Parvez
Rep Power: 16 |
Thanks for the reply.
Can you please comment on the error message bellow? what this mean? how to increase the table range? and will it help in convergence? +--------------------------------------------------------------------+ | ****** Notice ****** | While evaluating Total Enthalpy, | Static Pressure | went outside of its upper limit. Its maximum value was | 6.3200E+10. The bounds error was handled by clipping. | If this situation persists, consider increasing the table range. +--------------------------------------------------------------------+ |
January 17, 2010, 05:25 |
Rep Power: 143 |
As I said, your simulation has diverged. The message says the maximum pressure was 6e10. This is almost certainly physically impossible so is the sign of a rapidly diverging simulation. Only increase the table range if this pressure is likely to be correct. If it is not correct then fix the divergence and the problem will be fixed.
January 17, 2010, 08:30 |
George
Rep Power: 18 |
assuming you are modeling ionisation of argon, the plasma core can reach extreme temperatures in excess of 15K [K] hense the divergence.
if you have modified the fluid properties taking in to account the range of temperatures refine your mesh, use small timesteps and use underelax on enthalpy, entropy, conelec and jcur.
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
January 17, 2010, 08:34 |
Shahid Parvez
Rep Power: 16 |
What about the ramp loading concept? What if I apply 25 in first iteration then 25e1, 25e2.....and 25e6 in the succeeding iterations? will it help in convergence?
January 17, 2010, 08:44 |
George
Rep Power: 18 |
if the divergence is because of the high temperature thus your energy equation falls apart, do you think that ramping the flux will help? the emag module is also very demanding on the mesh resolution so sort your physics and mesh first, and as glenn said, get simplest physics possible to converge and add more complexity bit by bit
January 18, 2010, 23:06 |
#9 |
Shahid Parvez
Rep Power: 16 |
Dear Goerge
Thanks for the comments. Yes you right, its about the ionization of Argon. Can you please also comment on how to set under-relaxation(s) you mentioned in your post? |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
convergence problem | alexandre | FLUENT | 2 | June 14, 2007 14:31 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
