How to insert points to DesignModeler of Ansys? |
February 23, 2010, 21:01 |
ami
I am totally new to CFX. I am trying to simulate NACA 0012 with CFX. As the first step, I am trying to import the coordinates of NACA 0012 to DesignModeler in order to make the geometry. Can anybody help me about the format of the file and how I can import it?
Thank you very much. Ami |
February 24, 2010, 18:05 |
Ali Torbaty
this is the sample file format I copied from CFX help:
#------------------------------------------------------------ # List of Point Coordinates # Format is: integer Group, integer ID, X, Y, Z # all delimited by spaces, with nothing after the Z value. # Group 1 1 1 20.1234 25.4321 30.5678 1 2 25.2468 30.1357 35.1928 1 3 15.5555 16.6666 17.7777 #Group 2 2 1 50.0101 100.2021 7.1515 2 2 -22.3456 .8765 -.9876 2 3 21.1234 22.4321 23.5678 #------------------------------------------------------------ make a text file with above format, then to import into design modeller,goto [Create] menu -> Point and select the file you've just created. |
October 26, 2010, 14:27 |
#3 | |
akira glory
Hi, i tried to input this coordinate file, but an error keeps appear.
May I know where is my mistake? Quote:
October 26, 2010, 18:54 |
Ali Torbaty
October 26, 2010, 21:30 |
akira glory
I have found the cause of the error, there are two items with same id,
1 105 0.4645093 0.0980543 0 1 105 0.4566405 0.0984177 0 manual key in really cause alot of hassle |
February 10, 2012, 23:46 |
Niket Ghelani
Hello, I am a newbie. I am also trying to insert coordinates of Selig 1223 RTL, eppeler, etc. though the above comments are useful, I would just like to clarify one thing. Is the grouping of the coords based upon lower surface and the upper surface ?
Thanks for any help ! |
October 23, 2012, 05:50 |
Faraj
November 5, 2012, 08:47 |
Can Ansys support exponetial format?
Rick
I would like to know whether Ansys is able to support exponetial format. As in my text file, i specified it to be %g. Because my data value is too small, if i use %f, it will truncate to 0. Best Regards, natur3 |
December 6, 2012, 12:35 |
matt
I am doing a similar thing, importing coordinates and I can do that just fine, but how can I use these new points in a sketch? they seem completely separated and cannot be snapped to with lines. I can construct lines from points but i cant select those lines inside a sketch either.
July 29, 2013, 00:10 |
Import points in Ansys
Tonne Di
I cannot manage to import the .txt file, with the format given above, in order to insert some points... I am working with Ansys version 13.0. I can go to Ansys Main Menu > Preprocessor > Modelling > Create > Keypoints (?) > ..?.. Then I can't find the right window to browse and import my file. Also tried to import the text file via File > Read input from ... But this didn't work either. Can someone help me? Many thanks! |
July 29, 2013, 00:12 |
#11 |
Rep Power: 143 |
Try the ANSYS geometry and meshing forum.
January 7, 2014, 06:21 |
#12 |
shubham jain
Rep Power: 12 |
I successfully imported the coordinates of NACA 0012.
I need to import the coordinates of airfoil with some extrusion or protuberance. actually i want to import the coordinates of airfoil with gurney flap. Do I have to change the group of the points in .txt file or something else?? Kindly help |
March 12, 2014, 13:12 |
sa
#13 |
Rohit khatri
i am using fluent and i have excel file of nozzle geometry but i want to generate that geometry in ansys fluent so how i genrate text file from that excel file
March 12, 2014, 19:05 |
#14 |
shubham jain
Rep Power: 12 |
to generate txt file from excel, save the excel file as ".txt (tab delimited)" format to import the geometry into ansys.
u will need specific format of coordinates depending upon whether u are creating ur geomtery in Design Modeler or in ICEM CFD |
March 29, 2014, 06:31 |
#15 |
Hi Guys,
I am learning ansys DM, I have a fan coordinate points and modified it according to ansys text format, then create --> points --> .txt file which I created, I am able to see the points in DM. When I try to connect the points using spline, I couldn’t find the spline option in the sketch tap. how to get spline in DM or is there any other option? Thanks, Sivakumar |
March 29, 2014, 07:37 |
#16 |
Sorry for the post I got it,
it is under concept --> 3Dcurve (select Point select as definition) then select the points. Thanks, sivakumar |
April 9, 2014, 14:09 |
#17 |
Ashutosh
Rep Power: 12 |
I was successful in importing the co-ordinates of naca0015, as mentioned in this post. I created a 3D curve out of it. In the part, bodies it shows line body. When I click on it, it shows that the cross-section is not defined. May I know how to define this?
Another thing, I want to analyse flow over this airfoil in 2D. So, I need to create a rectangular domain over it. Then, I need to subtract the airfoil from this domain. However, the boolean option does not select this line body as the tool body. Also, I am not able to create a surface from this curve. How should I go about it? |
April 9, 2014, 15:10 |
#18 |
shubham jain
Rep Power: 12 |
@dreamz:
make sure ur line body is making a closed curve. surface can only be generated by closed curve. then apply boolean and for 0015... is zero camber airfoil so i think C-type domain (instead of rectangular domain) can also be good and easy for u |
April 10, 2014, 01:21 |
#19 |
Ashutosh
Rep Power: 12 |
@shubham
Please see the attachment. in the last line i had put 1 0 as mentioned in one of the post on this fourm.http://www.cfd-online.com/Forums/ansys-meshing/113097-import-3d-curve-txt.html I could not create a surface from the 3D curve. |
April 10, 2014, 04:57 |
#20 |
shubham jain
Rep Power: 12 |
first of all.. try to get more points..they are just 35 points.
try to get atleast 100 points from some online airfoil generator. second, yes, u need to put 1 0 in last point, to make a closed curve. try this attached file and check what is the difference in your file and mine, and let me know!!! |
ANSYS DesignModeler | Ema | ANSYS Meshing & Geometry | 3 | November 3, 2009 03:37 |
Insert of commands from classic in ansys in ansys w.b. | sirijo | ANSYS | 1 | October 24, 2009 10:09 |
ansys DesignModeler importing NAca | realanony87 | ANSYS Meshing & Geometry | 0 | May 28, 2009 16:29 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
