March 10, 2010, 13:45 |
Solver STOP with a variable
Roland Rakos
Hello CFX Users,
I have the next problem: I am investigating a displacement of a body which is moved by the flow forces. (I have defined the deforming mesh option in my simulation.) I would like to limit the value of the body displacement with the stop of the simulation. The next time range (the next position of the body) will be defined with a new mesh, therefore the simulation should be stopped by all means. (The mesh deformation is too high so the mesh has to be changed.) For example: I monitor the „Total Mesh Displacement Y” during the solver running. I would like to stop the solver when the Total Mesh Disp. reaches a certain value. Thanks in advance; Roland |
March 10, 2010, 16:43 |
Rep Power: 143 |
CFX V12 has user definable stops in it. There is no easy automatic way to do this if you are using an earlier version.
March 10, 2010, 18:08 |
Roland Rakos
March 10, 2010, 18:38 |
Rep Power: 143 |
The easiest approach is to upgrade to V12.
If you insist on doing it in V11 then I guess you could write out a monitor point, watch the monitor point file with a script and get the script to run the cfx5stop command when triggered. Messy but it should work. |
LES solver with variable density for incompressible liquids | matthias | OpenFOAM Running, Solving & CFD | 1 | April 26, 2010 05:46 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
Symmetry plane error in solver | Santiago Orrego. | CFX | 6 | January 31, 2007 07:09 |
Help, can't stop solver run...Windows OS | ben akih | CFX | 2 | November 13, 2006 10:05 |
Solver error message!!! | IoSa | CFX | 1 | September 14, 2006 04:48 |
