Material identification between a flow domain and a porous domain |
David fernandes
Rep Power: 0 ![]() |
Hi
![]() I’m trying to make a thermal transference between water, which is flowing in aluminum tube, and a porous material (graphite foam). The water (80°C) delivers, the thermal energy, when flowing in the aluminum conduct. The thermal energy is transferred from the water, through the aluminum conduct, and dissipated by the graphite foam though air by convection . In CFX I have to identify the different domains: Flow Domain: Air Flow Domain: Water Porous Domain: Graphite foam Solid Domain: Aluminum Problem: ![]() 1- I can’t identify different materials in the flow domain (Inlet water and inlet air) 2- The same happens between the porous domain and the flow domain. I can’t get the identification of the graphite foam material. It always identifies only one of the three materials that are present (Water, air, graphite foam). Can someone help me? (Sorry for the bad writing) ![]() |
coalboy
I have the same question,how do you slove it later ?
graphite foam, porous domain, water and air |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Material definition of a porous domain | Hitch8 | CFX | 0 | May 3, 2010 05:00 |
Porous domain in a flow field | rikio | CFX | 7 | August 25, 2009 22:39 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
