June 10, 2010, 10:09 |
One surface, two interface, is possibile?
Fabio
Rep Power: 16 |
Hi all,
my question is if is possible in CFX set two different interface for a single surface ? By default cfx says that there is a problem: same surface for 2 boundary condition. But how do you simulate a problem same mine? the picture explain the problem. The upper surface of Body A is in contact with air (body B) and another solid body ( Body C). body C is hot and i want simulate the distribution of temperature in body A so body A has 2 interface: one with body B and one with body C ...how set up cfx-pre? Thank you |
June 10, 2010, 18:24 |
Rep Power: 143 |
You have to split the interface on solid A into two sections. One section interfaces with B and the other with C. You cannot have a single surface interface with multiple domains.
June 11, 2010, 13:34 |
Daniel Paukner
Rep Power: 16 |
Maybe you could just use both downward faces of body C and Fluid B in the same Domain Interface definition.
Worked for me, but i connected one fluid domain face with two faces of separate solid domains. Alternatively, have you thought about building both solids as one model and defining the hot part as a subdomain? Might be another workaround. |
June 15, 2010, 03:03 |
Fabio
Rep Power: 16 |
thank u, now i try the second Pocket's solution
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
