Specify hybrid values for expressions in CFX-Post?
Like Tree1Likes
  • 1 Post By jtipton2
Old   August 12, 2010, 08:10
Default Specify hybrid values for expressions in CFX-Post?
Joseph Tipton
jtipton2 is on a distinguished road
When creating expressions in CFX-Post, is it possible to force a hybrid calculation?
This question stems from my desire to calculate an average Nusselt number on the top surface of the outlet of a rectangular channel. To obtain the average heat flux I am using the following expression:
lengthAve(Wall Heat Flux)@TopLineOut
Here's the problem...
  • If I open a result in CFX-Post and double click on my expression, I get a very large number (1.#INF [W m^-2]).
  • If I next go to the calculator and calculate "lengthAve(Wall Heat Flux)@TopLineOut" I first get the result "Undefined".
  • By pressing the "Hybrid" button, a reasonable value is then displayed.
  • Finally, if I then go back to the expressions tab and click on my custom expression, the reasonable value is displayed and any other custom expressions that use a hybrid variable suddenly display reasonable numbers also.
Does anyone have an idea what is happening? This is very annoying and keeps me from using the Workbench parameter study feature.
topsedar likes this.
jtipton2 is offline   Reply With Quote
Old   August 12, 2010, 18:36
Hybrid/conservative value thing does not apply to surface integrals on boundary faces, but you are trying to do a line integral I assume on a boundary face. What I would consider doing is to replace your line integral with a surface integral where the surface you are integrating over is thin, so it is just about a line anyway. Then you evaluate the area integral and that should work fine.
Old   July 20, 2013, 03:58
Hossein
topsedar is on a distinguished road
in CFX post go to:
Calculations ==> Function Calculator
then set your request. For example lengthAve(Wall Heat Flux)@TopLineOut
then at the bottom of Function Calculator tab, Press Hybrid button.
after this CFD Post automatically uses Hybrid Values For your Expression
topsedar is offline   Reply With Quote
cel expression, hybrid wall treatment
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
Acceleration in CFX Post LancelotCFD CFX 6 November 4, 2008 11:06
Hybrid and Conservative values alvio CFX 0 September 2, 2008 08:46
Mapping manipulated pressures back into CFX Post Molly CFX 0 August 27, 2008 07:52
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 14:59
