August 30, 2010, 09:32 |
Porous Domain
I am simulating a heat exchanger in CFX. I have data of velocity vs pressure drop. From this data I work out linear and quadratic resistance coefficients. The drop is in one direction only (the z direction in my model) so I specify a streamwise coefficient multiplier of 100 to block the flow in the other directions. What happens to the momentum in the x and y directions as the flow enters the domain - does it just disappear? The data for my heat exchanger is based on an inlet flow solely in the z direction but in my CFX model the flow has swirl before it enters. Therefore I need the CFX model to account for extra losses due to the flow approaching the heat exchanger at an angle. Can someone please help? |
August 30, 2010, 19:03 |
Rep Power: 143 |
CFX will simply put the resistance coefficients you specify in the cross directions, and this will slow the flow down until it approaches straight. If you want CFX to correctly model the deceleration of the swirl then you need to correctly specify the cross flow resistance coefficients.
Interface between fluid domain and porous domain | windhair | CFX | 6 | May 10, 2018 14:26 |
Radiation at interface between fluid and porous domain | Hitch8 | CFX | 19 | April 20, 2015 06:24 |
Material identification between a flow domain and a porous domain | Ervideiro | CFX | 1 | June 1, 2010 09:50 |
Heat transfer in porous domain CFX V12 | Hashmi | CFX | 0 | August 15, 2009 12:05 |
heat transfer in porous domain | Tiago | CFX | 3 | October 19, 2008 01:20 |
