August 30, 2010, 12:40 |
Error during the solver run
Roland Rakos
Hello CFX Users,
I’m calculating a 2D wing (NACA 0012) with SST. Re = ~3e6 so based on the help the Yplus has to be in range 20-100. This condition is OK but the solver shows during the run the next : ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | Wallscale | 0.73 | 3.2E-07 | 8.6E-06 | 23.9 6.5E-01 ok| +----------------------+------+---------+---------+------------------+ | U-Mom | 0.83 | 2.8E-04 | 1.2E-02 | 1.0E+00 F | | V-Mom | 1.51 | 8.3E-04 | 3.0E-02 | 1.5E+00 F | | W-Mom | 1.06 | 8.9E-22 | 8.3E-20 | 1.6E+14 * | | P-Mass | 0.95 | 1.9E-04 | 5.0E-03 | 9.0 2.0E+00 F | +----------------------+------+---------+---------+------------------+ | H-Energy | 1.93 | 1.6E-03 | 1.2E-01 | 5.7 7.8E-03 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.80 | 4.3E-04 | 1.5E-02 | 5.7 3.6E-02 OK| | O-TurbFreq | 0.69 | 7.3E-04 | 5.8E-02 | 11.7 1.4E-03 OK| I think that the mesh quality is correct. (2D stuctured hexahedral mesh). I don’t understand cause of the „ F and * ”. Thanks Roland |
August 30, 2010, 18:56 |
Rep Power: 143 |
This means the linear solver is not converging. You need to improve the stability of the simulation. The big problem is the W-mom equation - you say this is a 2D simulation but have you considered the issues mentioned here http://www.cfd-online.com/Wiki/Ansys..._simulation.3F
August 31, 2010, 02:16 |
Roland Rakos
Hello Glann,
OK, based on the document cause of the error is unambiguous. Thank you for your help; Roland |
Edit/stop run in progress without solver manager | N.R. | CFX | 12 | June 17, 2015 02:13 |
HOW can I run a solver without installatiom | waynezw0618 | OpenFOAM Installation | 1 | December 12, 2007 00:39 |
Symmetry plane error in solver | Santiago Orrego. | CFX | 6 | January 31, 2007 07:09 |
Help, can't stop solver run...Windows OS | ben akih | CFX | 2 | November 13, 2006 10:05 |
Customized solver to run in parallel | hsieh | OpenFOAM Running, Solving & CFD | 3 | September 21, 2006 04:59 |
