non-newtonian model
Old   October 5, 2010, 07:01
Default non-newtonian model
ali
alinematollahi is on a distinguished road
Hi
I'm going to a non-Newtonian models for blood do I use the models caro and casson. When the models for the following phrases (in cfx expression language)and I'll solve the problem, not a correct answer that it review the resulting graphs can be realized. When the models in the software I use, firstly when entering model casson
and begin to solve it is removed from the solver and Gives the following message. Do phrases are correctly expressed? And how do I use casson model?</SPAN></SPAN></SPAN>
casson model in CELsqrt(tawy/abs(min(uppers,max(sstrnr,lowers))))+sqrt(miuc))^2
tawy:6.7253e-04[kg m^-1 s^-2]
miuc:0.008[kg m^-1 s^-1]
uppers:300[s^-1]
lowers:0.00001[s^-1]
caro model in CEL:miubin+((miuzero-miubin)*(1+(a*((min(uppers,max(sstrnr,lowers))) ^2)))^n)
miubin:0.007888[kg m^-1 s^-1]
miuzero:0.12805[kg m^-1 s^-1]
uppers:300[s^-1]
error in casson (Models in software):
Details of error:-
Error detected by routine DELDIR
CDRNAM = get_VISCDYN
CRESLT = NONE
Current Directory : /FLOW/SOLUTION/TSTEP0/CLOOP0/ZN1/VERTICES/GLOBAL/MINIMUM
Details of error:-
Error detected by routine MAKDAT
CDANAM = LVAR CDTYPE = INTR ISIZE = 77
CRESLT = OLD
Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES
thank you very much
alinematollahi is offline   Reply With Quote
Old   October 6, 2010, 17:57
Michael P. Owen
michael_owen is on a distinguished road
Originally Posted by alinematollahi View Post
Hi
I'm going to a non-Newtonian models for blood do I use the models caro and casson. When the models for the following phrases (in cfx expression language)and I'll solve the problem, not a correct answer that it review the resulting graphs can be realized. When the models in the software I use, firstly when entering model casson and begin to solve it is removed from the solver and Gives the following message. Do phrases are correctly expressed? And how do I use casson model?</SPAN></SPAN></SPAN>
uppers:300[s^-1]
uppers:300[s^-1]
Details of error:-
CRESLT = NONE
Details of error:-
CRESLT = OLD
thank you very much
This is a bug. I have run into it. When you attempt to use one of the built in non-Newtonian viscosity models, it is not calculating the Dynamic Viscosity. You will have to create the model from CEL and just enter in the Dynamic Viscosity field in the material definition. I had to do this for the Cross model. Luckily all of the equations for the various models are well documented, so they are easy to recreate.
michael_owen is offline   Reply With Quote
Old   October 19, 2010, 06:09
ali
thank you michael_owen
Please you are right. But when casson model in its software that I use the numbers assigned to give error messages
uppers:300[s^-1]
Details of error:-
CRESLT = NONE
Details of error:-
CRESLT = OLD
thank you very much
Default non-newtonian fluid-casson model
ali
uppers:300[s^-1]
Details of error:-
CRESLT = NONE
Details of error:-
CRESLT = OLD
thank you very much
Old   October 19, 2010, 07:39
z
berelian90 is on a distinguished road
Dear Mr. nematollahi,
are you from iran?
i have used ansys cfx 12 for modeling an artery bifurcation in fsi
and i will be so grateful if you help me.
this is my email address:
zahra_farashah@yahoo.com
berelian90 is offline   Reply With Quote
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
