October 20, 2010, 02:11 |
need help for calculating friction factor
Rahul Vaibhav
Hi
I want to predict pressure drop over a model on a given flow rate. For benchmarking i took the cylinderical pipe and study the pressure drop for laminar and turbulent flow at various Re. i am trying to calculate fricition factor from moody chart (f=64/Re for laminar flow) and comparing it with cfx ( f = -(dp/dx)(2d/(rho*V^2)). but cfx friction factor is almost double in all the cases. i am could not find reason behind it. my BC inlet- mass flow rate (based on Re) outlet- static pressure =0 Thanks and Regards rv |
October 20, 2010, 04:46 |
Dynampally Pavitran
October 20, 2010, 05:05 |
Rahul Vaibhav
Hi Pavitran
Thank for the suggestiong you gave. Indeed i am not sure about the y+ values for turbulent flow so i am studying pressure drop of laminar flow in a pipe. I have taken a sufficient lenght of the pipe to make sure the flow become fully developed and i am calculating the pressure drop of fully developed region. Still i am not getting the right answer. |
October 20, 2010, 06:07 |
Rep Power: 143 |
Why are my results inaccurate? Been asked a million times, check out the FAQ:
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
October 20, 2010, 07:13 |
Rahul Vaibhav
thx ghorrock
i will go through it and it should help |
September 24, 2012, 13:50 |
regarding friction factor
abhi
even if we take total pressure difference is same as static pressure difference
my value is also deviating from expected value i don't know y ? expected is 0.128 and i am getting 0.145 but i am doing it in fluent plz tell me where am i going wrong ? |
February 28, 2018, 07:39 |
Davide
Rep Power: 9 |
the problem here is that u dont know the physics of the problem. check for lamina flow development...
fricition factor, pipe flow |
caculation of friction factor | Dilip | Main CFD Forum | 9 | February 23, 2016 05:00 |
How to incorporate the friction factor.... | Dewson | FLUENT | 0 | April 16, 2007 15:03 |
friction factor calculation in Fluent | Sandy | FLUENT | 0 | February 9, 2007 12:17 |
Skin friction factor | Ali | FLUENT | 2 | December 11, 2005 03:25 |
FRICTION FACTOR PLOT | hatta | FLUENT | 0 | February 22, 2004 13:38 |
