von Karman vortex street
Old   October 21, 2010, 13:04
Default von Karman vortex street
Dmitry Volkind
dvolkind is on a distinguished road
Greetings!
Though it might make some people sick, here is another question concerning vortex shedding.
Has anyone encountered a problem when vorticies move in the opposite direction and then get attached to the body?
My case: 2D, cylinder, oil, Re =100, laminar, and I'm sure about the time step. Mesh seems fine enough and it's symmetric. I use slightly asymmetric initial conditions for velocity (otherwise nothing happens, I guess due to mesh symmetry). CFX version is 12.1.
Sorry for asking about vortex street again, but I've read all the threads and found no answer. I would also very appreciate if someone gave me a link for a downloadable theory guide (it's a problem to find a paper book in English).
Thanks in advance,
Dmitry
dvolkind is offline   Reply With Quote
Old   October 21, 2010, 13:09
Michael P. Owen
michael_owen is on a distinguished road
Pictures would help.
michael_owen is offline   Reply With Quote
Old   October 21, 2010, 13:58
Dmitry Volkind
Sure, this is a link to a movie file: http://www.youtube.com/watch?v=_FLRZgnNvHo
Old   October 21, 2010, 14:04
Michael P. Owen
This is just a beat frequency effect between your vortex shedding frequency and your movie frame frequency. It's the same effect that makes videos of car wheels look like they are rotating slowly or backwards.
Old   October 21, 2010, 14:19
Dmitry Volkind
Will it help if I set results files to be written more freqently?
Old   October 21, 2010, 14:23
Michael P. Owen
Yes, of course. Set it to be a fraction of the vortex shedding frequency, say 1/10.
Old   October 24, 2010, 03:55
Ugly Kid Joe
vmlxb6 is on a distinguished road
What do you actually mean by asymmetric boundary conditions ??????
vmlxb6 is offline   Reply With Quote
Old   October 24, 2010, 06:03
Statements like this always set off warning bells - most of the time the mesh is not fine enough and the user is just assuming that because the cells are really little it must be fine.
But the only way to be sure is to do a sensitivity analysis. A basic mesh size comparison is a minimum, but more advanced methods are available to give you a much better handle on the accuracy of your mesh. See http://journaltool.asme.org/Template...umAccuracy.pdf for a summary or read "Computational Fluid Dynamics" by Roache for the full story.
Old   October 24, 2010, 13:46
Dmitry Volkind
Thank you, Glenn! I've already read this article (thanks to one of your posts) and I understand the importance of performing sensivity analysis before accepting final results. But this time I didn't do it because I made Yplus many times smaller then recommended for such cases, just to be sure of the mesh. Besides, the case is very simple and well known. So, everything you said is right, I'm just trying not to look stupid. CFD by Roach will be my next book after I'm done with Shlichting.
Thank you, Michael! I guess your point about "results output frequency/movie frame rate" is right, but I had no time to try it yet. After I try it I'll post if it helped.
Dear Prof. Chaos! I mentioned initial conditions, not boundary conditions. I made them asymmetric to initiate vortex shedding, because otherwise I've been getting two symmetric vorticies, which stayed "attached" to the cylinder. I thought the reason was mesh symmetry that leaded to symmetric error accumulation -> no unsteadiness. I'd greatly appreciate any comments on that.
Dmitry
Old   October 24, 2010, 13:53
Ugly Kid Joe
How did you incorporate asymmetric initial conditions ??????
Old   October 24, 2010, 14:03
Dmitry Volkind
To Prof. Chaos: Initial velocity = linear function of X, where X is a coordinate across the flow.
Old   October 26, 2010, 08:35
Dmitry Volkind
Yes, Michael was right! Output frequency was the problem. More trn results fixed it.
Thanks everybody!
Old   February 14, 2011, 19:08
Adrian Dunne
ad281 is on a distinguished road
I thought I'd just post my problem in this thread to avoid posting any more threads.
My model has ended up looking like this after 350 timesteps.
http://img841.imageshack.us/i/vortes.jpg/
This doesn't look right, and I'm not quite sure why.
Can anyone suggest a reason?
flow velocity = 16m/s
Timestep = 0.002s
Last edited by wyldckat; September 3, 2015 at 18:04. Reason: disabled embedded images
ad281 is offline   Reply With Quote
Old   February 15, 2011, 06:23
What looks wrong about it? It looks about right to me.
Old   February 15, 2011, 08:56
Adrian Dunne
The large region at the tail where the flow is diminished greatly.
I've done others with a different mesh, and that looked more similar to examples I've seen.
Old   February 15, 2011, 16:45
You mean how the vortex street does not reach the outlet boundary? You simply have not run it for long enough. Keep going and it will get there.
Old   February 15, 2011, 19:27
Adrian Dunne
No, I mean how there's a big blue region at the tail of the vortex street.
Normally the vortices decay, when I look at other examples like.
Old   February 15, 2011, 19:30
What are the velocity vectors doing in that region? You never said what velocity component you showed in the image.
I still think it is just a startup thing and you just need to run longer.
Old   February 16, 2011, 06:16
Adrian Dunne
The velocity component in the picture is absolute, not in any particular direction.
You're probably right, not having run it for enough timesteps is probably the reason it looks like that.
Thanks for your help.
von Karman vortex street. Vortices formation mechanism. mnvl Main CFD Forum 1 February 24, 2010 17:53
Are these reverse von karman vortex street? quarkz Main CFD Forum 1 August 20, 2009 15:15
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
Von karman Vortex street yoshi Main CFD Forum 6 September 10, 2005 22:09
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel L. Könözsy Main CFD Forum 0 April 17, 2000 13:16
