Question from tutorial: Buoyant flow in a partitioned cavity |
October 28, 2010, 05:48 |
Noppawit Sippawit
I'm trying to simulate a case really similar to the tutorial of Buoyant flow in a Partitioned cavity (Chapter 8). From the tutorial, the air (Material: Air at 25 C) is initially at 5ºC and one side is heated up with fixed temperature of 75ºC and the opposite side is maintained at 5ºC. From the result, why the pressure changes not so much? In my opinion refers to ideal gas law, the pressure should increase about 0.25atm. If I want to see 0.25atm increasing, how can I do? And also, what is the different between "Total Pressure" and "Pressure"? Thank you so much. Noppawit |
October 28, 2010, 18:14 |
Rep Power: 143 |
October 31, 2010, 21:00 |
Noppawit Sippawit
Does anyone know how to maintain constant volume?
October 31, 2010, 21:05 |
Rep Power: 143 |
? In a closed cavity if you don't move the mesh you keep a constant volume.
October 31, 2010, 21:21 |
Noppawit Sippawit
Thank you for your replies, I'm afraid that I still don't understand why my case doesn't follow Ideal Gas Law. Since you've mentioned that static mesh, volume is constant.
When I heat the gas, it should follow . But from the simulation, it doesn't follow. From my understanding after I switched material to "Air Ideal Gas", CFX calculate the density of air after change in temperature, and it uses calculated density to calculate pressure. I tried to initialize the initial (static) pressure, also vary this initial pressure -->> the result is still the same (very small change in pressure). Since my gas is a kind of gas expansion, how can I do it? |
November 1, 2010, 09:44 |
Michael P. Owen
Are you running in steady state, or transient?
November 1, 2010, 09:54 |
Noppawit Sippawit
I have tried both of them. But they are the same, I mean they don't follow ideal gas law. From my result above is transient, at 2s.
November 1, 2010, 09:57 |
Michael P. Owen
Are you setting the pressure level?
November 1, 2010, 10:03 |
Noppawit Sippawit
I really don't know what is pressure level? Where should I set it?
If you mean the initialization, I've already tried. But the result is still the same. I tried with 1atm, 2atm,.. in the box of static pressure. |
November 1, 2010, 10:39 |
Michael P. Owen
The model is not conserving mass.
1. Make sure you are using Air Ideal Gas, and NOT Air at 25 C. 2. Run in Transient 3. Make sure that your Heat Transfer option (Domain definition, Fluid Models tab) is set to Total Energy OR 3a. If you use the Thermal Energy option, make sure that you set the minimum number of coefficient loops (Solver Control, Basic Settings tab) to 2 4. On the Solver Control, Basic Settings tab, check on Conservation Target. The default setting may be to loose for a transient simulation with a lot of time steps. Lower it if your mass conservation is poor. 4. On the Advanced Options tab of the Solver Control, check on Pressure Level Information and check on Compressible Transient Option. |
November 2, 2010, 10:31 |
#11 |
Noppawit Sippawit
Thank you for your reply. I'm trying on michael_owen's method. Roughly, the pressure increases about 2000Pa.
March 18, 2014, 11:06 |
#12 | |
Hi, I've the same problem in a steady state simulation. How can I change this setting for my case? thank you |
March 18, 2014, 16:53 |
#13 |
Rep Power: 143 |
It is a transient only option. You should not need to do this sort of thing. Can you explain your problem more fully? I bet there is another more important problem causing it.
March 19, 2014, 02:18 |
#14 |
Hi Glenn,
I answered you in another post. By the way my problem is the same of noppawit but in steady state. I tried this tutorial but internal Absolute Pressure doesn't change with temperature |
Urgent: Unsteady 3-D supersonic cavity flow | Min-Sung Kang | FLUENT | 3 | April 6, 2014 09:50 |
[blockMesh] basic blockMesh : manipulate the lid-driven cavity flow tutorials | Lexa | OpenFOAM Meshing & Mesh Conversion | 2 | November 12, 2009 21:15 |
CFX gravity driven free surface flow tutorial | mechovator | CFX | 37 | July 27, 2009 10:28 |
Supersonic Flow over a Cavity (coodles): Maximum Iterations Exceeded | sushant | OpenFOAM Running, Solving & CFD | 0 | April 9, 2009 02:52 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
