buoyancy - losses estimation through total pressure
Old   October 29, 2010, 14:07
Default buoyancy - losses estimation through total pressure
clrsgfn is on a distinguished road
Hi everyone
As a test, I'm simulating a basic vertical cylinder, with uniform normal water flow at entrance and zero averaged pressure at outlet. Reynolds number is ~2000
- When buyoancy is off, by calculating total pressure difference between inlet and outlet I get losses that corresponds to what can be expected from theory
- when buoyancy is on : computing losses by total pressure difference gives a very different value (*20 !). Computing losses by difference of (abs pressure+cinetic energy) gives non physical results (negative losses...)
I've checked hydrostatic pressure (abs. pressure - ref. pressure - pressure) and this is ok...
what's going on ? and how do I compute losses in case of buoyancy ?
thank you all in advance !
clrsgfn is offline   Reply With Quote
Old   October 30, 2010, 11:32
Tommy
TommySean is on a distinguished road
If there's setting about reference density, you can make a test with reference density = 0.
TommySean is offline   Reply With Quote
Old   November 1, 2010, 13:03
thanks
but I am not considering a multiphase flow, as only water is flowing in. So my density is fixed and constant (i am not considering temperature fluctuation either). This is really a simple test case, and results are puzzling to me...
any other clue ?
Old   November 4, 2010, 12:10
Michael P. Owen
michael_owen is on a distinguished road
Originally Posted by clrsgfn View Post
Hi everyone
The absolute pressure is equal to the reference pressure plus the pressure. P_abs - P_ref - P is not P_hydrostatic, it's zero. The reason your pressure difference is so large is that the Pressure includes the hydrostatic pressure. What is the height of the cylinder? You have a hydrostatic pressure difference of rho*g*h. Subtract that from delta P and you will get your losses.
michael_owen is offline   Reply With Quote
Old   November 10, 2010, 11:05
Hi michael,
thanks for your contribution.
I've understood that when buoyancy is on, absolute pressure = pref+pressure+hydrostatic pressure (this is what is said in CFX help).
In fact I did a wrong calculation when buoyancy was on as my reference temperature was set in kelvin and not in celsius as I thought. Now that I fixed it, total pressure difference when buoyancy is on or off are the same.
Therefore, I still have questions about hydrostatic contribution :
when buoyancy is on, total pressure difference as defined by CFX (pressure without hydrostatic contribution + cinetic energy) between inlet and outlet should be regular losses + rho.g.deltaz
and this is not the case, we get only regular losses.
Could it be that when imposing boundary conditions, hydrostatic contribution is implied, therefore in the pressure field obtained, hydrostatic contribution is indeed included in PRESSURE ?
Thanks.
buoyancy, losses, total pressure
total pressure change in a pipe flow Im FLUENT 5 February 23, 2017 08:55
conservative total pressure and density Atit Koonsrisuk CFX 0 June 24, 2007 12:45
resistance & pressure losses Jan CFX 0 May 14, 2002 07:33
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 08:53
