Stationary Simulation of Shock Wave with Instationary Settings |
November 4, 2010, 08:38 |
Hi everbody,
I am not very keen in setting up Ansys Pre with the right configuration data like time step and duration. I read that its quite common to calculate such problems with discrete equations of first order in accuracy. Can anybody help me with the settings or with advice? greetings |
November 4, 2010, 16:49 |
Rep Power: 143 |
I do not understand your question. If you are asking how do you implement first order time and space schemes, then this can be set under the solver tab.
November 5, 2010, 12:35 |
I want to simulate a stationary incoming flow to a truncated cone with supersonic inlet. I read that for stationary incoming flow with supersonic speed there is a disadvantage in the way of solving the differential equations (eliptical/hyperbolical). So its better to solve while using transient flow settings (just hyperbolic). But I am just interessted in the stationary solution of the problem so its suficient to use the equtions of first order. But I have no idea how to set up these things like time step and so on..
November 5, 2010, 15:19 |
Rep Power: 143 |
how to model shock wave generated from detonation? | Maddy | FLUENT | 13 | August 31, 2020 08:18 |
Re: Pressure wave simulation | taha | Main CFD Forum | 0 | August 23, 2004 10:55 |
shock wave propagation | Chetan | FLUENT | 1 | April 20, 2004 14:45 |
simulation of breaking solitary wave | mehdi icho | Main CFD Forum | 0 | July 2, 2002 04:35 |
1 dimensional shock simulation | N Menon | CFX | 1 | January 7, 2002 11:07 |
