CFX Solver Error
Old   November 7, 2010, 10:55
Default CFX Solver Error
Pavelistyj
Pavelko is on a distinguished road
When I'm starting a run I get the following error:
The CFX Solver for system Fluid did not produce the result file. No output file is available. Cell B5
Do any one have an idea what the problerm is?
Thanks in advance,
Pavel
Pavelko is offline   Reply With Quote
Old   November 12, 2010, 08:33
RossFS is on a distinguished road
Assuming that the solver window has come up and started before producing this error message:
*Are you running the simulation in parallel? Try running serial instead if this is the case.
*Is your time step too large?
*How accurate are your initialisation settings/conditions?
I'm sure there are many other things that could be the cause, but the above are things that I've encountered in my limited experience with CFX simulations.
RossFS is offline   Reply With Quote
Old   November 12, 2010, 08:41
Pavelistyj
Thank you,
I've found the mistake - the problem was in solution initialization.
Old   March 18, 2011, 09:35
Omar
ista is on a distinguished road
I'm having the same error. Please can you indicate me with more details what was the problem in solution initialisation? I'm trying to run the tutorial 21, but I don't find the field which I need to change.
Thank you
ista is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
