November 9, 2010, 20:27 |
Modelling Vapour Pressure in CFX
Callum Johnston
Rep Power: 15 |
I'm wishing to model a system, part of which involves measuring the change in the vapour pressure of water due to a heat impulse.
I believed I could do this in CFX after seeing some promotional material stating that it had models for evaporation and condensation. However, I'm new to CFX and am having trouble understanding how to implement this. I've worked through some of the tutorials provided with CFX but none of them seem to cover evaporation. Does anyone have a tutorial or advice as to how I'd go about implementing condensation or evaporation? |
November 10, 2010, 16:37 |
Rep Power: 143 |
I don't think any tutorial examples cover evaporation. Talk to CFX support, they might have an example simulation.
November 10, 2010, 16:55 |
Callum Johnston
Rep Power: 15 |
Ok thanks for the info. I'll stop looking for some and will get in touch with CFX support.
Cheers, Callum |
November 11, 2010, 00:10 |
Rep Power: 143 |
There is the spray drier tutorial. It does evaporation of water droplets in hot air, using lagrangian particle tracking. Is this of use?
November 11, 2010, 03:13 |
playmaster
Rep Power: 15 |
You can check the (Axial Turbine Equilibrium and Non-Equilibrium Steam Predictions) tutorial to see the inverse phenomenon, where vapor is condensed in the last stages of steam turbines and water droplet is generated. I will give you an insight to solve your problem.
November 11, 2010, 16:03 |
Callum Johnston
Rep Power: 15 |
Thanks Glenn and Playmaster. I've glanced through both tutorials quickly and am going to work through them now. I think combining parts from each I should be able to make some progress.
Is CFX incapable of modelling a compression ramp in 2D? | RossFS | CFX | 23 | November 7, 2010 17:32 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
Multiphase modelling in CFX | sam | CFX | 2 | July 12, 2003 01:17 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 05:05 |
