How to set up transient one way coupling?
Old   November 16, 2010, 14:41
Smile How to set up transient one way coupling?
Ji Pei
peiji1984 is on a distinguished road
Hello everyone!
From the "Oscillating Plate with Two-Way Fluid-Structure Interaction" in CFX Tutorials and other documents, I found that generally for ANSYS packet(CFX and multi-field solvor) two way coupling calculation can be transient, but many cases for one way coupling are steady. I mean, like exporting the CFX result files and adding it to strucure in Workbench manually for each time step.
How can I set up a transient one way coupling calculation using MFX which can be calculate for every time step automatically, or some other mehtod? I didn't find many statements about it in ANSYS help, just something about using "Additional Coupling Sent Data" for coupling wall boundary specification and setting the mesh motion to stationay in CFX Pre. Is that way OK? It seems to be OK, but I am not sure. Also, if to do so, is just single stagger iteration enough? Convergence criterion for stagger iteration is unmeaningful, right?
Thank you~
peiji1984 is offline   Reply With Quote
Old   March 18, 2011, 08:52
Jean-François Morissette
jfmorissette is on a distinguished road
actually, ANSYS doesn't make it really obvious, but the way to dot it is to use the transient 2-way FSI framework, but in CFX, you could specify to not send back displacement to CFX, so only fluid forces will be transfered to ansys.
Hope it will help!
jfmorissette is offline   Reply With Quote
Old   March 18, 2011, 09:44
Ji Pei
Thank you for your reply and help, jfmorissette! It is very kind of you.
I think you are right, ANSYS doesn't make it really obvious. That's why I am not sure that this way is right or not.
Ji Pei
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
set temperature on subdomain, in transient mode nicolas CFX 0 August 16, 2006 06:42
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 19:28
