November 27, 2010, 23:47 |
derivative in CEL expressions
ali
Hi
How can I use derivative or gradient in CEL expressions? I need to use derivative of velocity with respect to time in one of my boundary conditions. Regards |
November 28, 2010, 14:09 |
Guess it requires user fortran.
November 28, 2010, 17:02 |
Rep Power: 143 |
Read the documentation about derivative and gradient functions. But you are out of luck - CEL does not support time derivatives. You might be able to grab the variable from something else eg the time derivative of mass is a mass flow rate and MFR can be read directly. If that is not possible then you will have to use fortran.
November 30, 2010, 04:03 |
Actually, you can get the Time Derivative of variables, but you have to employ user fortran (e.g. a User CEL Function). For example:
... CALL USER_GETVAR('Water.Temperature.Time Derivative',CRESLT, & pTDer,CZ,DZ,IZ,LZ,RZ) ... |
November 30, 2010, 18:03 |
Edmund Singer P.E.
Rep Power: 20 |
Actuallly you can get the derivative from last time step to current time step via use of additional variables settings. If you create an additional variable of the velocity, and add the term using ccl in the ADDITIONAL VARIABLE term:
Update Loop = TRANS_LOOP This will cause that variable to take the old value of the velocity. You can use it to create your derivative. |
November 30, 2010, 18:25 |
Rep Power: 143 |
That is a nice trick Edmind, I did not know that one. Very useful.
December 1, 2010, 01:33 |
ali
I didn't get it right. Still I need to use USER_FORTRAN. isn't it?
December 1, 2010, 09:44 |
Edmund Singer P.E.
Rep Power: 20 |
No need to use user Fortran. As an example, edit the additional variable in your LIBRARY with the update loop as follows:
ADDITIONAL VARIABLE: OldVel Option = Definition Tensor Type = SCALAR Units = [m s^-1] Variable Type = Specific Update Loop = TRANS_LOOP END You can then use this to create your derivative. |
December 1, 2010, 09:54 |
ali
Thank you very much edmund!
April 4, 2011, 09:05 |
Matjaz Fleisinger
could this procedure be also used to sum the calculated velocities for every time step in the past? How could this be achieved anyway? Thank you! Matjaz |
April 4, 2011, 09:32 |
#11 |
Edmund Singer P.E.
Rep Power: 20 |
Yes this can. But you need to initialize the variable with a separate artifical run.
For example if you use additional variable Q=Q+1, this will work fine except for the first iteration if Q hasn't been intialized, because CFX will complain that Q doesnt exist for the right hand side of the equation. CFX doesn't let you initialize an algebraic AV (at least at V12.1, havent checked into V13). The workaround is to run a sinlge iteration with the AV set to zero. This result will be saved to the res file. On the next run you set up your AV with the summing expression and use the res file from the first run to initialize it |
April 4, 2011, 10:12 |
#12 |
Matjaz Fleisinger
Thank you very much, exactly that happens in my Ansys v13.
Regards, Matjaz |
April 5, 2011, 03:59 |
#13 |
Matjaz Fleisinger
another question regarding my problem, could this accumulation of delta velocities from all the previous timesteps using this technique, my AV can not be used as a source velocity for the current timestep. Is it possible to pass it around? Thank you, Matjaz |
April 5, 2011, 09:28 |
#14 |
Edmund Singer P.E.
Rep Power: 20 |
I am unclear on what you are asking.
April 5, 2011, 10:04 |
#15 |
Matjaz Fleisinger
I can not use my AV as a source for a velocity at a start of next time step. Should there be used some callback function, as areaAve, which would return a value? Even when i try to monitor the value during the run, i recive an error, because the AV isn't single valued or sth. like that.
I don't know much about these additional variables, haven't use them much. Regards, Matjaz |
April 5, 2011, 10:24 |
#16 |
Edmund Singer P.E.
Rep Power: 20 |
Ohh, yes of course. Use one of the functions to evaluate it and make it single valued.
April 6, 2011, 05:18 |
#17 |
Matjaz Fleisinger
Hello, i still need some more guidelines for this procedure;
I did edit my AV in cmd editor with trans_loop, then checked name of this AV in both of my domains, where i also wrote expression for AV: velocity = velocity + delta_velocity. Then i created new expression, using areaAve of AV on a 2d locator in my moving domain, and created monitor point of that expression. Unfortunately simulation runs, but my velocity doesn't sum all the previous ones, or it does it much too slow. Did I miss something here? Thank you, Matjaz |
April 6, 2011, 09:27 |
#18 |
Edmund Singer P.E.
Rep Power: 20 |
Where are you getting your delta_velocity from?
April 6, 2011, 09:32 |
#19 |
Matjaz Fleisinger
I get it from user fortran routine, it works fine, just need to accumulate all the past values for current time stem; my trouble is, that i can not save it to a file, but also don't want to bother with mms, which i'm also not familiar with.
April 6, 2011, 09:35 |
#20 |
Edmund Singer P.E.
Rep Power: 20 |
You are getting it from a fortran routine that you are calling while CFX is running (User Fortran?)
Or are you getting it from a pre-ran fortran routine, and delta_velocity is already set for the CFX run. |
Cel expressions | RAMAN6089 | CFX | 13 | November 30, 2009 23:17 |
junction box routine and CEL function | bornspur | CFX | 2 | February 3, 2009 02:24 |
Cel expressions for trasient problem | Jervds | CFX | 0 | March 4, 2008 10:03 |
Cel expressions Time dependent | Juan Maria Campos | CFX | 8 | December 27, 2007 18:16 |
CEL Expressions | Nick | CFX | 3 | September 25, 2007 14:54 |
