January 5, 2011, 08:10 |
Order of interpolation
Reine Granström
I have not managed to find any info in the CFX-12 documentation regarding how the interpolation is done when using CFX-Post in "comparison mode" to compare different meshes. Basically, I would like to know what the order of the interpolation is, and how it is carried out. Also, I would like to know the equivalent for the CFX Solver interpolator. Is the same method of interpolation used? Thanks, Reine |
February 17, 2011, 07:32 |
Update
Reine Granström
Since I have been in contact with the support I have learned that CFX-Post uses a trilinear interpolation of first order. Presumably, the interpolation in the solver is also of first order accuracy.
For example, imagine carrying out a grid refinement study using a second order scheme. It concerns me a bit that this first order approximation will limit the overall accuracy, if one would like to compare local quantities rather than some global variable. Any thoughts on this? In Celik's [1] paper on Richardson extrapolation, they use a "third order Newton's Divided Difference Polynomial" to interpolate the results between different grids. However, I have not seen the use of higher order interpolation methods elsewhere than in this paper. I would appreciate any recommendations on literature regarding methods for interpolation. [1] Celik, I., Karatekin, O. Numerical experiments on application of Richardson extrapolation with nonuniform grids (1997) Journal of Fluids Engineering, Transactions of the ASME, 119 (3), pp. 584-589. |
February 17, 2011, 10:07 |
Update#2
Reine Granström
Also, correct me if I am wrong, as I have understood a 1D linear interpolation (CDS) between two nodes of a regular grid is second order accurate. i.e. the leading truncation error term is proportional to the square of the distance between the nodes and the polynomial order is 1.
And, as I have understood, a trilinear interpolation is identical to three successive linear interpolations. Therefore, it seems to me that a trilinear interpolation (on a regular grid) should also be second order accurate. However, at Wikipedia's page for Trilinear_interpolation it is written that: "The order of accuracy is 1 for all these interpolation schemes" (linear, bilinear and trilinear ) Can someone clear this out for me? Is it a general statement that holds for all grid types? |
February 17, 2011, 21:17 |
#4 | |
Rep Power: 143 |
Be careful here - the interpolation for initial condition calculations or comparisons between results file is done by trilinear interpolation, but the advection discretisation is second order by default. The advection scheme is totally different to the interpolation schemes. I think you have interpolation schemes mixed up with advection schemes. |
February 18, 2011, 02:50 |
#5 | |
Reine Granström
Hi Glenn,
Thank you for your reply. I am only referring to the interpolation scheme, not the advection scheme. Quote:
Kind regards, Reine |
February 18, 2011, 06:01 |
Rep Power: 143 |
I think you would have to talk to CFX support for the details of the interpolators, beyond what is shown in the documentation.
interpolation |
second order interpolation | white heart | Main CFD Forum | 1 | April 22, 2010 08:36 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 14:32 |
High order interpolation | mbuffat | OpenFOAM Running, Solving & CFD | 0 | October 15, 2008 03:47 |
Fourth order surface normal gradient interpolation | adona058 | OpenFOAM Running, Solving & CFD | 8 | September 24, 2007 15:12 |
2nd order interpolation for NS solver | Quarkz | Main CFD Forum | 6 | July 15, 2005 21:50 |
