cfx solver crash when writing results
Old   January 18, 2011, 02:57
Default cfx solver crash when writing results
Denis
siden is on a distinguished road
hello.
I have a big prolem here.
the CFX solver crashes when i want to write a .res ok .bak file by stopping ok backuping my computation.
i have this message:
Slave: 4
Slave: 4 Details of error:-
Slave: 4 ----------------
Slave: 4 Error detected by routine DELDIR
Slave: 4 CDRNAM = /FLOW/GETVAR/NEWT_FIT
Slave: 4 CRESLT = NONE
Slave: 4
Slave: 4 Current Directory : /FLOW/PHYSICS/MATERIALS/MT9/PSTAT
Parallel run: Received message from slave
Slave partition : 4
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1032
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine MEMERR |
I'm using ansys 13.0 on a win7 64bit machine.
I though it was a problem of right management but i made another test with another case and it's ok.
siden is offline   Reply With Quote
Old   January 27, 2011, 19:51
Ji Guozhao
jiguozhao is on a distinguished road
Hi:
I also have a problem in solver.
when simulating flow through plane membrane, it is ok. but when simulating the situation of passing hollow fiber, the cfx solver does not work for me.
| ********* WARNING ********* |
| The initial values file does not contain any field solution data. |
| Please check the source file carefully. |
| ****** PROBLEM REPORT ****** |
| Subsystem: Input |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| Stopped in routine CHECK_INTERP |
did you solved your problem? friend?
if you already have dealed with that, can you help me?
Ji
g.ji@uq.edu.au
jiguozhao is offline   Reply With Quote
Error message CFX Solver Fatnes CFX 25 July 3, 2015 10:32
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
Problem with cfx Solver Results Ordoumpozanis CFX 4 August 27, 2008 11:54
CFX 11, solver Debabrata CFX 1 June 16, 2008 21:52
cfx solver error sandhesh CFX 3 June 6, 2008 10:13
