February 20, 2011, 00:42 |
question about boundary conditions
Nick
Rep Power: 15 |
Hi all,
I'd like to simulate the flow over an infinite wing. For this purpose I created a rectangular domain and created part of the wing inside the domain. I have a problem setting the correct side walls (those that are parallel to the airfoil cross sections). If I set them as symmetry from what I understand it basically prevents spanwise flow normal to the sides walls which would not be realistic. Should I set them as periodic in order to simulate an infinite wing? Please note that this is not a 2d problem. I'd appreciate it, if you could give me the instructions in steps (I've never done a period BC (if this is what is needed). Thanks! |
February 21, 2011, 00:52 |
Rep Power: 143 |
If you are expecting your infinite wing to generate 3D structures then you should do with periodic boundaries, with a distance between periodic boundaries at least as long as the biggest 3D structure you expect to see, and preferably several times that size.
Periodic boundaries are just a type of interface. Choose the interface type as periodic and the option as translational. |
February 21, 2011, 18:58 |
Nick
Rep Power: 15 |
Thanks for the comments Glenn. I'll give it a try.
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
Algorithm for coupled pde with all flux boundary conditions | benk | Main CFD Forum | 3 | December 28, 2010 05:09 |
question about implementing boundary conditions | saygin | Main CFD Forum | 0 | July 6, 2006 07:08 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
