March 6, 2011, 19:42 |
inlet temp = outlet temp
Rep Power: 15 |
I have an urgent problem with my cfx setup. I am using Ansys 13 CFX Workbench. My problem is I want to set the inlet temperature as it is at the domains outlet, so it is like a circle. The fluid is being warmed up in that domain. I have read I have to use a DEFINE_PROFILE UDF in that case. But I never used UDFs before and I do not have enough time to search for a good tutorial. Please can someone help me how to set up my analysis to solve my problem. Inlet name: Oil Inlet Outlet name: Oil Outlet Or do you have a link to a turorial or another method how to solve this? Thanks, Romek |
March 7, 2011, 00:42 |
Rep Power: 15 |
Just figured out I can do it via Expressions.
The Statement would be "Tin = areaAve(Oil.T)@Oil Outlet" Can someone confirm this? |
March 7, 2011, 18:54 |
Rep Power: 143 |
Looks OK. Have you considered using a periodic boundary condition?
March 7, 2011, 19:55 |
Rep Power: 15 |
whats is the difference of the periodic boundary condition?
right now i have a static temperature at the inlet calculated by the expression above. |
March 7, 2011, 21:01 |
Rep Power: 15 |
i have an other problem.
i am simulating the oil flow in an engine. So the pressure level in the galleries ishould be over 3 bar depending on the engine revs. But the pressure level in the oil pan should be atm. When I simulate it as one domain the pressure level in the galleries is ok, but in the oil pan region drops to -0.6 bar rel. pressure. Inlet/Outlet mass flow (which is the same) control the boundary conditions. The domain contains oil and air. What is the best way to set up these conditions? Split it up in 2 domains? Or create an opening for pressure control in the oil pan? |
March 9, 2011, 02:23 |
plz help
Rep Power: 15 |
Hi, I think i have a similar problem to define my boundary conditions
i have two narrow long pipes in contreflow configuration so in total i have 4 fluid boundaries to declare in CFX-pre (2 inlets and 2 outlets). well I know the inlet conditions of the first pipe (Temp, pressure and Mass flow rate) Tin1, Pin1, mRin1 As for the second tube inlet conditions i'd like to define them as similar to the first pipe's outlet (Temp, Pressure and mass flow rate) i.e: Tin2=Tout1, Pin2=Tout1, ... How i Can do that I'm quite new user of CFX and i don't know how to define this inlet conditions in CFX-pre. probably with expression right ? can you send me the right tutorial or defintion if possible thank you |
March 9, 2011, 20:10 |
Rep Power: 15 |
@ afrit: download "Ansys CFX Reference Guide" for that. You will find it in Chapters 14/15.
Please can someone help me with my problem? |
Mapping outlet patch to inlet patch of new case | val46 | OpenFOAM | 0 | February 18, 2011 11:22 |
Boundary conditions: inlet and outlet | aline | OpenFOAM | 7 | June 29, 2010 03:45 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Inlet & Outlet Boundaries causing low surface temp | Ted Crilly | Siemens | 2 | November 19, 2004 08:58 |
how to set inlet and outlet? | green | Phoenics | 5 | May 18, 2004 23:52 |
