Heat Transfer Coefficient in Compressible Flow 3D turbine cascade
Old   March 10, 2011, 15:35
Default Heat Transfer Coefficient in Compressible Flow 3D turbine cascade
Karkoura is on a distinguished road
I am using CFX to model a 3D turbine cascade. My ultimate objective is to compute the heat transfer coefficient distribution at the blade surface.
The flow is subsonic compressible so I am using "Total Energy" and "Air Ideal Gas" for the working fluid.
CFD Post outputs data for two particular variables. The "wall heat flux (q) " and the "wall heat transfer coefficient (h) ". From the CFX manual, I understand that these two are related by:
h = q / (T_wall - T_adjacentwall)
These values are very high and not in agreement with experimental data.
I tried to compute the wall heat flux myself by using the following:
q = -k * (Twall - Tadjacent wall) / y
where
k is the thermal diffusivity
Twall is the wall temperature (which I had specified as a boundary condition)
Tadjacent wall is the temperature of the first node away from the wall.
and
y is the distance of the first node away from the wall to the wall itself (this value I defined when I was creating the O-grid mesh around the airfoil in ICEM CFD)
Still I see that the variable are underpredicted compared to experimental data and the trend of heat transfer distribution with streamwise direction on the blade surface is not smooth and fluctuating.
I would appreciate any comments and knowledge you can share about computing the heat transfer coefficient in compressible flow.
Thank you so in advance.
Karkoura is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 4 January 24, 2017 14:30
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
