ansys-cfx12 CEL function error
Old   April 17, 2011, 04:28
Default ansys-cfx12 CEL function error
nayyer
Rada is on a distinguished road
I'm working with an User Fortran routine interfacing with ansys cfx.
my problem is look like cfx-tutorial chapter 19 under title of "air conditioning". as the test case for linking CEL I did all options in this tutorial but when I write Command
( ! system ("cfx5mkext TStat_Control.F") == 0 or die "cfx5mkext failed"; ) in command line, The following error appears.
"ERROR
CCL parser failed with message:
Perl Syntax errors detected:
cfx5mkext failed at(eval 86) line1. "
In fact I couldn't run cfx tutorial at first step!!!
could anyone help me about this error???
Thanks to all, and thanks to CFDonline!!
Rada is offline   Reply With Quote
Old   April 18, 2011, 15:22
joey2007 is on a distinguished road
For windows:
  • use a command line tool for compiling
  • use ifortvars script from intel to set the environment and path variables
  • if you really want to exactly like the tutorial you have to:
    • start a command line
    • ifortvars
    • start cfx5pre on this command line
Please do not forget: I am not paid for answering your questions.
Thousands of issues can cause a division by zero. Please do not capture a thread, with the argument: "I have the same issue ...."
joey2007 is offline   Reply With Quote
Old   April 19, 2011, 02:18
nayyer
Originally Posted by joey2007 View Post
For windows:
    • ifortvars
dear joey
thanks for your answer.
which programs should i install for comiling?
I think the error is because of having no program for compiling!!!
best regards
Old   April 22, 2011, 14:13
windows: intel compiler plus some development kits from microsoft. Do not have exactly in mind which. Check help or manual.
linux: portland group or gnufortran
Old   April 26, 2011, 03:09
Default which version
nayyer
thanks Dear joey
which version of "intel fortran compiler" should I install for ansys V12??
should I install "microsoft sdk platform"??
the Error I face with is ((The compiler command "ifort" could not be found.Please ensure that the compiler is on your PATH and try again)).
thanks alot
Old   April 26, 2011, 04:10
Do not know. Check the manual for that.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
