Outlet Boundary Condition
Old   April 24, 2011, 19:30
Question Outlet Boundary Condition
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All
I want to simulate blood flow inside a curved artery with constant diameter along the artery (artery doesn’t have any constriction). I know the pressure value at inlet of artery but I do not know the mass flow and pressure at outlet. I want to find the pressure value at outlet. Does anybody know what type of boundary condition should be used at outlet in order to get the outlet pressure value by considering that mass flow rate is unknown.
Kind regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   April 25, 2011, 08:48
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
dear friend there you have a difficult problem, first of all it is a non newtonian flow, so you have to introduce the dependence between the sheear strees and the deformation of the fluid, and furthemore you will need at least the velocity at the outlet.
If i were you i would use, flow at the inlet and an outflow at the outlet
juliom is offline   Reply With Quote
Old   April 25, 2011, 08:53
Cool
Ashkan Javadzadegan
Dear juliom,
Thank you very much for your kind reply. The problem is that I do not know the flow rate. I have got the physiological pressure value at inlet of a healthy artery and I am trying to find how much pressure would be droped along the artery and that is why I need to get the pressure value at outlet.
Best wishes,
AshtonJ
Old   April 25, 2011, 09:05
Julio Mendez
Ok, look my dear friend. If you use just pressure as a boundary condition you will have a system which is non robust. Remember that the equation system requires to be closed by the boundaries conditions and the only way to couple them is through the conservation law and the mometum law. I sugest you to read more about the SIMPLE algorithm. Then you will see why you should use the other type of boundaries conditions.!!! I would like to help you but is not easy in that way
Old   April 25, 2011, 19:36
Question
Ashkan Javadzadegan
Dear juliom,
Again thanks. Do you know how I can impose "outflow" boundary condition in CFX-Pre. I checked all available boundary conditions in CFX-Pre but I could not find "outflow".
Best wishes,
AshtonJ
Old   April 26, 2011, 02:22
Lance
Lance is on a distinguished road
Originally Posted by ashtonJ View Post
Dear juliom,
Best wishes,
AshtonJ
If you checked all the boundary conditions in CFX you would have found "outlet" (and "opening"). Have a read in the documentation about them.
Lance is offline   Reply With Quote
Old   April 26, 2011, 08:09
Julio Mendez
Hello my friend, when you use a condition of "outflow", you are forcing the the system to take out all the fluid from the domain. However the "outlets" are one kind of outflow, since you have to set up different properties.
Indeed you can use pressure at the inlet and the outlet but I am quite sure that you will have problem with the solver, perhaps an overflow problem or it will not solve the problem and you will have convergence problem.
You should use at least one condition with velocity or flow.
Remember that Patankar defined, in his book, "outflow" as a condition where the gradient at the outlet is zero for all the propierties minus the V (vertical velocity).
I hope this will help you
Outlet Pressure-flow coupled boundary condition (Windkessel) cfdfsi Fluent UDF and Scheme Programming 3 July 21, 2017 12:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
Outlet boundary condition CN FLUENT 6 May 22, 2005 09:37
