clarification needed
Old   May 6, 2011, 04:24
Default clarification needed
Govindaraju
kmgraju is on a distinguished road
I did steady state analysis in a pipe.
I need some clarification on pressure in the cfx post.I beg your pardon to ask the fundamental question.
in my result
The pressure is varying from inlet to outlet.
The flow velocity is constant then why the pressure is not uniform for the entire length?
The following is my setup.
LIBRARY:
CEL:
EXPRESSIONS:
vin = 2*0.1[m s^-1]*(1-r^2/(0.0015[m])^2)
END
END
MATERIAL: Blood
Material Group = User
Option = Pure Substance
Thermodynamic State = Liquid
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 1050 [kg m^-3]
Molar Mass = 1.0 [kg kmol^-1]
Option = Value
END
DYNAMIC VISCOSITY:
Option = Non Newtonian Model
NON NEWTONIAN VISCOSITY MODEL:
High Shear Viscosity = 0.00345 [Pa s]
Low Shear Viscosity = 0.056 [Pa s]
Option = Bird Carreau
Power Law Index = 0.3568
Time Constant = 3.313 [s]
END
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: Default Domain
Coord Frame = Coord 0
Domain Type = Fluid
Location = B6
BOUNDARY: Default Domain Default
Boundary Type = WALL
Location = F9.6
BOUNDARY CONDITIONS:
MASS AND MOMENTUM:
Option = No Slip Wall
END
END
END
BOUNDARY: inlet
Boundary Type = INLET
Location = F8.6
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Cartesian Velocity Components
U = 0 [m s^-1]
V = 0 [m s^-1]
W = vin
END
END
END
BOUNDARY: outlet
Boundary Type = OUTLET
Location = F7.6
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [Pa]
END
END
FLUID DEFINITION: Fluid 1
Material = Blood
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = None
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic with Value
U = 0 [m s^-1]
V = 0 [m s^-1]
W = vin
END
STATIC PRESSURE:
Option = Automatic
END
END
END
OUTPUT CONTROL:
MONITOR OBJECTS:
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR POINT: Monitor Point 1
Cartesian Coordinates = 0.0[m],0.0[m],0.0[m]
Option = Cartesian Coordinates
Output Variables List = Pressure
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Minimum Number of Iterations = 1
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = On
END
END
END
COMMAND FILE:
Version = 13.0
Results Version = 13.0
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = Off
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: govindaraju
Host Architecture String = winnt
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = Fluid Flow CFX.def
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END
END
END
kmgraju is offline   Reply With Quote
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Windows XP Batch file help needed DL123 Main CFD Forum 2 July 3, 2009 08:53
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
CFD Software Engineer needed in Fort Worth, Texas Ross Main CFD Forum 0 November 19, 2001 14:48
