Periodic Interface (Ideal Gas) Massflow Control |
Rep Power: 15 ![]() |
I want to to a translational periodicity and use the material ideal gas. My results using Air at 25° are converging and I can set a specific mass flow at the interface. But I am not allowed to set a mass flow rate at an interface using air ideal gas. If I set it to none, my mass flow is asymptotically going to zero .... almost zero after 50 iteration ...... do I have to set a momentum source? Or whats the solution? Thanks in advance! |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
