August 24, 2011, 12:16 |
Rotating Frame of Reference
fluhid
Rep Power: 14 |
Hey community!
Firstly, I would like to say what a great resource this is and how thankful I am to be a part of it. I am a junior mechanical engineer, and aspiring hydraulic engineer. I am relatively new to CFX software but have a good foundation of theory behind fluid dynamics. I will continue to post my findings and questions and hopefully they can be of help to others that have relative issues. I have a multi-domain, steady state simulation with 3D geometry of a water passage (one domain - stationary) imported from SW and inside this geometry is a 5 blade kaplan turbine (second domain - rotating). It has meshed well and I have specified inlet (mass flow-rate) and outlet (static pressure) conditions. I am interested in any areas of cavitation and a preliminary efficiency that I can compare to a physical model test that was performed. I am wondering, initially, is this the right approach? I am trying to model a complete water passage from intake to draft tube with a rotating turbine inside it. However, the walls are also part of the rotating domain and I'm not sure if that's correct to simulate. Should I have a counter-rotating wall in this domain? Any help is more than appreciated! Thanks |
August 24, 2011, 18:41 |
Rep Power: 143 |
There is a FAQ in the CFX documentation on rotating machinery which will help you. Have you read it? That would be the best place to start.
August 26, 2011, 16:31 |
fluhid
Rep Power: 14 |
@Ghorrocks,
I have read most of the User Guides for Mesh, Pre, Solver, and Post. While all of them are great resources, tutorials and examples don't deal with large area simulations or only deal with water-to-blade passages in a symmetric nature. Also, I am not using turbo mode, as I have modeled only the water passage as a single part by taking existing geometry and creating a internal "mold" of the cavity. I have performed a simulation and had convergence but I don't believe my results are accurate. I have attached a .jpeg of the velocity streamline through the water passage. My concern is that my stationary domains aren't properly effected by my rotating domain. Any ideas? |
August 26, 2011, 22:03 |
Rep Power: 143 |
What is not properly affected by it?
August 29, 2011, 13:22 |
fluhid
Rep Power: 14 |
Firstly, the blades are spinning in the wrong direction, which is quite evident from the uploaded jpeg image, and my next simulation will be corrected. What I am concerned with is the fact that there is no residual swirl in streamlines as the flow leaves the rotating domain and a sudden change in velocity. Why is that?
August 29, 2011, 18:39 |
#6 | ||
Rep Power: 143 |
Should write an FAQ on this, this question has been asked many times. Quote:
August 30, 2011, 08:47 |
fluhid
Rep Power: 14 |
Okay, I'll give it a try. Thanks so much for your valuable feedback, I really appreciate it.
cavitation, multi domain, rotating domain, turbine, water passage |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
