Newtons method failed to converge in 100 iterations |
September 2, 2011, 12:21 |
Bostjan
hey all, after giving all boundary condition for gas combustion, i got following error during solver. Please help me to understand this error.
Anybody are experienced in this? any suggestion on this problem? Parallel run: Received message from slave ----------------------------------------- Slave partition : 3 Slave routine : NEWT_FIT Master location : End of Continuity Loop Message label : 009100013 Message follows below - : +--------------------------------------------------------------------+ | ****** Notice ****** | | Newtons method failed to converge in 100 iterations. This | | occurred while computing the following variable: | | | | Variable Name : Temperature | | Location Name : Default Domain | | Mesh location : VERTICES | | Mesh entity : | | Last 3 Changes : 1.64457E-01 1.64457E-01 1.64457E-01 | | Tolerance : 1.0000E-02 | | | | The Newton iteration was either slowly converging or has stalled. | | The solver will continue with the variable set as it was on the | | final iteration. If this situation continues you might try | | increasing the number of iterations allowed for Newtons method. | | This can be changed by setting one of the parameters: | | | | Temperature : "Constitutive Relation Iteration Limit" | | Pressure : "Newton Pressure Iteration Limit" | | | | for your mixture using the definition file editor. | +--------------------------------------------------------------------+ |
September 2, 2011, 18:37 |
Rep Power: 143 |
What type of material properties are you using?
September 3, 2011, 03:10 |
Bostjan
For Gas Air mixture i used reacting mixture, material group: gas phase combustion, mixture properties: ideal mixture
For O2, CO2, H20,...material properties: ideal gas, NASA format This problem has appeared when i increased heat transfer (heat flux) for 1000- times (from -300 W/m2 to -30 000 W/m2) for wall boundary conditions... Last edited by brajh11; September 3, 2011 at 03:35. |
September 3, 2011, 05:56 |
Rep Power: 143 |
Combustion models are always hard to keep stable. I suspect you will need smaller timesteps to resolve the combustion transient. But that's only a guess.
September 3, 2011, 06:24 |
Bostjan
i solved my problem steady state not transient.
For Timescale Control i have changed from Auto Timescale to Physical Timescale 0.008s but now the solver said: +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Overflow | | | | | | | | | | | +--------------------------------------------------------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 4 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1033 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | | | | | | | | | | +--------------------------------------------------------------------+ |
September 3, 2011, 06:29 |
Rep Power: 143 |
OK, that error message means you have improved things but it still cannot converge. You need smaller time steps.
Newtons Method failed to converge in 100 iteration | hagupta | CFX | 9 | December 2, 2010 06:41 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
