How to add a new variable in the list of variables for MESH ADAPTATION ?? |
Vladimir
Rep Power: 0 ![]() |
Good afternoon, colleagues! I have specific enough question, which decision it is real, but it is not described in documentation.
I have CFX versions 12.0, for my problem it is necessary to add the new variable, described by some expression, depending on other variables, such as components of speed of a stream, in the list of variables accessible to MESH ADAPTATION. How I can make it? I will be very grateful for any help!!! |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Sounds straight forward. Have a look how variables are set up in the CFX tutorial examples.
Vladimir
I read the documentation. To add a variable using the expression means cfx-pre impossible. Even the variable is created in the cfx-pre can not simply add to the list of available variables to mesh adaptation. I have a suggestion what to use MMS ... I would be grateful for any tips! Thanks in advance!
Timothy
Rep Power: 16 ![]() |
Assuming I understand what you want to do, you should try this.
Create an additional variable. You will need to specify if it is a vector or scalar and the units of the new variable. Go to default domain and under additional variables define how CFX should calculate your new variable. I assume that the variable you created will show up in the mesh adaption variables list. Hope that helps, Timothy |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
diffusion Term for add. Variable | Zaktatir | CFX | 9 | July 16, 2011 09:51 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
